Old 12-29-2012, 10:26 AM   #1
72chevynoob
spring cutting?
I have the front end of my '69 torn apatt for a disc brake swap, and I figured I moght as well lower it while I am at it. I have two spring choices. The regular ones frkm the '69, and heavy duty ones from an'81. Which should J use? I plan on cutting 1 ring off.
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 12-29-2012, 11:25 AM   #2
Rusbuilt
Rusbuilt's Avatar
Re: spring cutting?
I would say if your truck sat level with the original springs I would cut and use those.
Rusbuilt is offline   Reply With Quote
Old 01-29-2013, 08:03 PM   #3
Square_78
Square_78's Avatar
Re: spring cutting?
I would use the heavy springs. The 1/2 ton springs are too soft for a lowered truck in my opinion.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 01-29-2013, 08:52 PM   #4
72chevynoob
Re: spring cutting?
I agree. I cut the original ones, which I found soft before, and it dropped way more than I expected. It seems like Im going to have issues with bottoming out, so I will probably put the heavier springs in sometime.
Justin
