Old 12-29-2012, 05:47 PM   #1
tp85
waht to strip from I6 to use with V8?
I just pulled my I6-250 to swap in a V8-350. don't have the SBC yet, so....
what accessories, brackets, etc. should i remove from the I6 because I will need them for the V8? plan to sell or give away the I6.
engine mounts? flexplate? starter? power steering?
thanks,
tom
tp85 is offline   Reply With Quote
Old 12-29-2012, 09:17 PM   #2
duallyjams
duallyjams's Avatar
Re: waht to strip from I6 to use with V8?
All the brackets are different. If you decide to give away or throw away let me know I'll come and get it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-29-2012, 09:30 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Actually, if you want the V8 mounted in the "correct" position you will need a set of V8 engine stands as well (part that bolts to frame and crossmember). Plenty of guys have put their v8's in the I-6 position but the motor will sit farther back and if you run HEI it will be pretty close to the firewall. Are you sticking with the trans that's in it? Not sure how moving/not moving the engine stands will affect that.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-30-2012, 08:08 AM   #4
tp85
My blazer is a 4X4. From what I have been told, Chevy had the engine close to the firewall on these 4X4 trucks. Sticking with the sm465 and np205. Although I would like to move the V8 forward, I think shifting the engine, tranny, and transfer case forward would cause problems with the front. driveshaft . Do I have this wrong ?
Old 12-30-2012, 08:17 AM   #5
Legolas894
Chemist under the hood...
Legolas894's Avatar
Mine was swapped from an I-6 to 283V8. It sits way back clost to the firewall but it still works ok. I've got a non-HEI set up so that might be why it works for me. It does but the fan pretty far from the rad though.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 12-30-2012, 06:29 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
RUbber engine mounts, flexplate and bolts, starter, alternator, oil and temperature sending units.
Tx Firefighter is offline   Reply With Quote
Old 12-30-2012, 08:11 AM   #7
tp85
Awesome, thanks, how about the wiring harness... for the connectors perhaps?
Old 12-30-2012, 11:55 AM   #8
Tx Firefighter
Just lay the harness out of the way when you remove the old engine. It's part of the truck. Then you can modify it as needed when the new engine is in place and the harness draped over it so you can see which wires you want to modify to fit best.
Old 12-30-2012, 10:14 PM   #9
tp85
Thanks, makes sense now that you mentioned the obvious. Guess I forgot to mention I pulled the body off the frame, wire harness off the body/frame, so I sort of left the harness move with the engine. I'll keep the harness to re-install if I don't buy a new harness.
Tom
