12-29-2012, 07:22 PM | #1 |
djm lower control arm shock mounting
the djm lower arms i put on my blazer have very large shock bolts that wont fit though stock or belltech shocks.anyone ran into this before?do i need to buy djm shocks?
12-30-2012, 01:09 PM | #2 |
67-72 parts collector,…
Re: djm lower control arm shock mounting
Do you have any pics?
Does it have a bolt or a shock stud?
12-30-2012, 01:42 PM | #3 |
djms have a regular bolt with a spacer that goes into a threaded part of the a-arm.
'69 Fleet It ain't yours, if you didn't build it! |
12-30-2012, 09:40 PM | #4 |
thanks for the reply.i think i am going too cut out the incorrect sized nuts on the arms and weld in the proper ones.tried to remove the sleeve on the shocks
and they would not budge. |
05-08-2013, 06:04 PM | #5 |
Old thread, I know. I'm running into this issue now too. It was my stopping point for yesterday.
http://http://67-72chevytrucks.com/v...d.php?t=578181 |
05-08-2013, 10:05 PM | #6 |
ended up drilling shock bushing out so the bolt would fit.think i used a 5/8" drill bit
12-30-2012, 01:31 PM | #7 |
I had the same problem when I installed my djm arms. I just took out the metal insert on the shock and it fit. I also had to buy different size of spacers.
It was kinda frustrating, but I did this on a Sunday and needed the truck for Monday so I didn't call jdm to ask about it.
05-22-2013, 12:01 AM | #8 |
Pics always make it much easier to get answers
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
05-22-2013, 11:10 AM | #9 |
I drilled mine out, forgot what size bit I used. After a while the bushing and rubber got hot and then bushing came out.
