Old 12-30-2012, 02:27 PM   #1
1964Chevy
1964Chevy's Avatar
New Radiator what else?
I ordered an aluminum rad, 16" electric fan, thermostat controlled switch with A/C override.
I plan on replacing top and bottom rad hoses, thermostat gasket (it's seeping), alt and A/C belts, and checking that the water pump is working.
My old radiator is leaking in several spots. I like the looks of an open area in front of the motor, my truck has never overheated (knock on wood) but I know the rad is going fast, new leaks everytime I look.
My question, if it was you what else would you do with the rad and fan out of the way?
PS, it appears that the water pump is working fine, what is the shade tree mechanic way of checking this with all the stuff out of the way.
Bought a 3 core aluminim rad with a 16" fan, supposed to pull 2500 CFM, from Reliableradiator.com
Hope you all have a safe happy new year.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline   Reply With Quote
Old 12-30-2012, 06:32 PM   #2
j.kirn
Re: New Radiator what else?
Did you check the heater core
j.kirn is offline   Reply With Quote
Old 12-31-2012, 01:14 AM   #3
Captainfab
60-66 Nut
If there are no obvious signs of the water pump leaking, you can check the bearings by grabbing the fan and rocking it front to back, and see if they are loose. A little movement is ok.
Old 01-01-2013, 05:39 PM   #4
1964Chevy
1964Chevy's Avatar
Good idea about the heater core. I think I will flush the core out with a water hose. I will test the water pump.
