Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-31-2012, 05:10 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
1.77 60ft
I was really Impressed yesterday I cut a 1.777 60 ft 8.06 in the 1/8 on a poorly prepped track with track prep applied on my tires and bunch of people push down on my truck when I launched, its just a cam and bolt on 6.0 makes 370 to the wheel, with a 4l80e tight 3600stall, factory big 10 suspension "8 pack 56"springs", cut coil up front, no front sway bar, beltec drop shocks, and nt555r at 9 psi, but I ran the same time when I cut a 1.84 60 ft, back in the summer I was e/t streets the best 60 was a 1.91, with 8.40 1/8
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-31-2012, 05:22 PM   #2
Super73
Super73's Avatar
Re: 1.77 60ft
Good deal.
Tried finding info in your build thread.
Was the 370rwhp with the converter locked or unlocked?
Where does the motor make peak TQ? Get your converter re-stalled to that rpm or even 200rpm past, and I bet you go quite a bit faster in the 60'
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-31-2012, 05:31 PM   #3
flamingbig10
6.0 powered square
Re: 1.77 60ft
I believe unlocked, the stall is a yank pro multi disk 258mm, I called yank and they said it cant be re stalled, but I'm switching to a single disk pi 3600, caltacs, slicks, and a 150 shot
Aaron
Old 12-31-2012, 09:54 PM   #4
Super73
Super73's Avatar
Re: 1.77 60ft
Do you lock the verter going down the strip? If not, try locking it in 2nd right after peak TQ. When I had an 80E it picked up roughly 3.5mph and .1-.15 ET on motor when doing so. I bet on the hose it would have show even better gains.
Why are you going to swap a multidisk for a single? Reason I ask is from what I understand the multidisk will have better clamping force than the single. If you are going to spray it and lock it, keep the multi disk!
I'd keep the yank, re-stall it to 4,500 and let it rip both on the motor and on the bottle.
Old 12-31-2012, 10:04 PM   #5
flamingbig10
6.0 powered square
Re: 1.77 60ft
I called yank and they said they can't re-stall it, the guy told be the stall is made for towing in a 3/4 with turbo or supercharger, but I like to have the lock up on toggle switch
Aaron
Old 01-01-2013, 10:49 AM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 1.77 60ft
If you use the generally accepted conversion of...
(1/8 ET + 0.22)/ 0.655
Your 1/4 mile is mid 12.6s Pretty respectable and much better then I'd expect for a stock 6.0 in a full size (even set up very well).
And....
if the optimum 60' time = 0.12 * 1/4 mile et + 0.17 (and using the 12.64 from above)
A kick butt sixty would be 1.6anything. The 1.tripple seven on anything but a slick is impressive.
Kudos,, on a combination that is very well done!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-08-2013, 11:12 AM   #7
redsled87
redsled87's Avatar
Re: 1.77 60ft
And....
Guess a 1.686 on a bfg drag radial is really good then. Didn' t mean to steal the thread. Those are a real improvement. I remember what I ran with my sbc. Ran a best ever of 13.25 @ almost 104. Going 11's really surprised me. Anyway, good luck and keep it up!
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 01-01-2013, 02:41 PM   #8
flamingbig10
6.0 powered square
Re: 1.77 60ft
thanks, I never thought this truck was going to run this well with the few mods I have, I have knocked off a full second from my first time out, I ran a 2.18 60ft, 8.95 1/8 82, 13.74 at 98,with hooking on street tires, stock convertor, and a mail order tune
Aaron
Old 01-02-2013, 08:07 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1.77 60ft
Props on the build . Brought that truck back to life .
Made my first trip to Texas motorplex not to long ago . Bet those balcony seats are bada$$ during the nationals
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-08-2013, 12:39 PM   #10
Super73
Super73's Avatar
Re: 1.77 60ft
I have run Nitto's bfg's and mt's. by traction it goes in this order mt's, bfg's, Nitto's.
Marv, you are not looking it the right spot for fast DR stuff. Here are a couple examples:
http://ls1tech.com/forums/drag-racin...man-ftmfw.html
http://ls1tech.com/forums/drag-racin...1-27-60-a.html
http://ls1tech.com/forums/drag-racin...os-radial.html
http://ls1tech.com/forums/drag-racin...a-radials.html
Old 01-08-2013, 03:59 PM   #11
redsled87
redsled87's Avatar
Re: 1.77 60ft
Good to know as, I have a pair of M/T 325/50/15 ET Street Radials in the basement for this season(hopefully).
60' 1.49
1/4 10.93
MPH 120
Old 01-31-2013, 11:40 PM   #12
flamingbig10
6.0 powered square
Re: 1.77 60ft
got the converter swapped and a new fuel pump my old one would drop down to 38, cut another 1.77 60 ft barley stalling the truck up with much thicker air than before with a 8.2 1/8, got the nitrous kit installed just needs colder plugs and a tune going start small with a 75 shot
Aaron
Old 02-01-2013, 01:34 AM   #13
Super73
Super73's Avatar
Re: 1.77 60ft
Aaron, play around with launch technique. Some times off idle to wide open transitions cut better 60's than stalling up on the converter as far as possible.
Put the n20 kit on a WOT switch, leave off idle and let it rip. shutting off right after the stripe and coast to a stop. Pull a plug and put a replacement in. Cut it open in the pits and take a good look at it. Adjust AFR as needed.
Old 02-02-2013, 12:21 PM   #14
flamingbig10
6.0 powered square
Re: 1.77 60ft
I'm going to the track today so I'll mess around with launching on motor, my tuner is going to do a nitrous tune, but I'll see if he can go to the track when I do the first nitrous pass
Aaron
Old 02-02-2013, 01:15 PM   #15
DesertCat
DesertCat's Avatar
Talking Re: 1.77 60ft
Originally Posted by flamingbig10 View Post
...and bunch of people push down on my truck when I launched,....
does NHRA allow this now?
must be some rule changes lately....
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 02-02-2013, 02:40 PM   #16
Super73
Super73's Avatar
Re: 1.77 60ft
Aaron,
I would not worry too much about changing anything in the tune if you are only spraying 75. Put a TR6 plug in it and call it a day. Once you start spraying 100+ then definately start pulling a little timing.
What kit are you using?
Old 02-03-2013, 12:57 AM   #17
flamingbig10
6.0 powered square
Re: 1.77 60ft
That truck is pretty much street racing on track no rules, they'll race even if its raining, I will run the tr6 plugs, best pass was a 1.79 60ft 7.95 1/8@85 12.46@106 1/4
Aaron
Old 02-03-2013, 01:28 AM   #18
flamingbig10
6.0 powered square
Re: 1.77 60ft
A nitrous outlet plate system
Aaron
Old 02-03-2013, 12:44 PM   #19
flamingbig10
6.0 powered square
Re: 1.77 60ft
Aaron
Old 02-03-2013, 03:21 PM   #20
Super73
Super73's Avatar
Re: 1.77 60ft
Aaron, clean out you pm's.. Trying to send you one
Old 02-03-2013, 10:40 PM   #21
flamingbig10
6.0 powered square
Re: 1.77 60ft
I emptied them out
Aaron
