01-01-2013, 02:01 AM | #1 |
My Carbon Footprint
Wiring diagram for headlight switch?
I'm going a custom gauge cluster and I'm not going to use the factory headlight switch. I need to know what wires control the marker/cruising lights and the headlights. I'm just going to run them off a toggle switch on a panel. I see the switch has a plug with numbered male ends on the switch. Can someone tell me what is what? Thanks!
01-01-2013, 02:09 AM | #2 |
Re: Wiring diagram for headlight switch?
Try this http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Posted via Mobile Device |
01-01-2013, 02:20 AM | #3 |
My Carbon Footprint
I'm assuming the GMCs and Chevys are the same? Thanks for the link!
01-01-2013, 10:38 AM | #4 | |
01-01-2013, 06:04 AM | #5 |
Also need to consider that the factory headlamp circuit breaker is part of the switch. So if you remove the switch there will be no circuit protection. Even if you are going to add headlamp relays you should plan on a fuse or circuit breaker on the control side.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-01-2013, 11:07 AM | #6 |
My Carbon Footprint
Great points from both of you. I do realize about the fused part and that will be addressed. Thanks again.
01-01-2013, 02:02 PM | #7 |
Active Member
Here's a GMC v8 schematic for engine compartment in case you need it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
