01-05-2013, 03:03 AM | #1 |
who makes the best aluminum rear mount fuel tank?
OK I looked and searched and can not find what I am looking for seen one I like but forgot to write down who made it I am putting the tank in the back and want to know who makes the best aluminum tank for between frame rails? I also want 8an fittings in and out of tank so future fuel usage and want one with a sender already in tank for original 0-30 ohm gauges. Pictures would even be better I dont really like the jegs tanks I want one that fits good heigth is not a issue its 4x4 and has a 8" lift on it
01-05-2013, 05:14 AM | #2 |
Re: who makes the best aluminum rear mount fuel tank?
check out www.boydwelding.com
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
01-05-2013, 11:39 AM | #3 |
hey did that fit in your truck good? didnt see one on there site for our trucks but I like how it looks mind if ask how much it cost?
01-05-2013, 12:16 PM | #4 |
Boyd's! I fit it in my truck, no issues.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-05-2013, 12:39 PM | #5 |
I also want to do this - need the leg room in the cab. Looks like this doesn't come with sending units etc - where are you guys picking up the extra pieces to the puzzle? Thanks in advance.
01-05-2013, 02:43 PM | #6 |
took the words out of my mouth buddy the only senders they show are 0-90 and we need 0-30 ohm i dont even see on there site where the 60-66 trucks are listed
01-05-2013, 06:02 PM | #7 |
They will supply them, tell them what you have. Mine came with roll over valve, sender and cap.
01-05-2013, 07:15 PM | #8 |
IF you need a sender you can also contact Classic Instruments as this is where Boyd gets his stuff from. The tank fits awesome and I'm putting a second one in my daily driver now since I'm rebuilding the motor.
01-05-2013, 07:21 PM | #9 |
the tanks were designed for the 67-72 trucks but fit ours as well. they also give members a discount . best price out there.
01-06-2013, 01:47 AM | #10 |
60-66 Nut
If you need something different than the standard offering, I believe Dave Boyd can accomodate you. Give him a call or PM him here on the forum.....he is a forum Vendor.
http://www.67-72chevytrucks.com/vboa...d.php?t=362307
01-06-2013, 03:54 PM | #11 |
anyone have any installed pics? how low does it hang, as i intend to lay frame and dont want it to hit the ground. my buddy bought the blazer tank and it hangs way too low.
Posted via Mobile Device |
01-09-2013, 12:43 PM | #12 |
If you are laying frame and raising the bed floor, you can mount the tank on top of the frame rails for extra clearance.
01-09-2013, 01:20 PM | #13 |
Pro-
Can you PM me a quote for the Porterbuilt Stage 2 Deluxe rear and a boyd tank with roll over valve (not sure if you can get a 30 ohm sending unit) - for my 1964 short bed step side shipped to 08085? Are there any known issues with clearances on the short bed with this tank? Thanks in advance. -W |
01-09-2013, 03:56 PM | #14 |
CPP has a tank that fits between the rails.
The stock filler it offset. I relocated the filler in the center
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
01-09-2013, 04:35 PM | #15 | |
- Travis |
01-09-2013, 04:50 PM | #16 |
hey Pro could you also get me a quote on both tanks with 0-30 ohm senders and would prefer 1/2 outlet for fuel lines thanks and shipping to 66070
01-09-2013, 04:56 PM | #17 |
PM Sent, thanks.
01-09-2013, 06:59 PM | #18 |
any thing for a 60? Pm sent
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-14-2013, 08:50 PM | #19 |
01-09-2013, 07:11 PM | #20 |
Pm Returned. Can do a custom tank or maybe adapt the Boyd tank to your frame with some brackets. I sent you measurements also.
- Travis |
01-10-2013, 12:13 AM | #21 |
how did you all hook up the fill hose to the truck? any pics of how you did this? or how bout pics of the bed fill pics I am thinking of the bed fill style so dont have to cut something out on the side but would like to see how you did it
01-15-2013, 12:21 PM | #22 |
No problem at all.... glad to get you all set up and appreciate the business. I will keep you posted when they ship out.
Travis |
01-15-2013, 01:56 PM | #23 |
here are the dimensions for my 1960 tank, it fits like a glove hope they help.
A
Link to my 60 http://67-72chevytrucks.com/vboard/s...d.php?t=537517 |
01-18-2013, 11:46 PM | #24 |
Got mine at Classic Performance Parts and had no issues.
