Filler neck grommit
I just installed my tank and a new grommit on my 63 but it doesn't look quite right. Does the wide part of the grommit face down or up? Maybe I just have the tube sticking to far out..not sure. Thanks
Re: Filler neck grommit
There is a small
Notch on the bottom to align the grommet up and down. Hope the helps Glenn Posted via Mobile Device
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
There is a notch on the bottom of the opening for the filler tube on the cab, line bump on the grommet with this notch.
Now i'm wondering if I got the correct grommit. I don't recall there being a bump in the grommit to fit the notch on the truck.
Just put mine on yesterday, and can confirm what the others already said. Sheetmetal has a slight notch where the little bump on the grommet fits into, and the thickest part of the grommet that shows points straight back. The little bump is easy to miss if you aren't looking for it, but once you see it, it's impossible to miss.
The widest part of the grommet appears to be towards the rear of truck. The alignment bump on the grommet can be seen easily from the backside of the grommet. you will also see the bump on the inside of the rubber grommet where it contacts the notch on the cab to keep it from turning.
man those are a Bear to install
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
