Old 01-05-2013, 11:22 PM   #1
1970greenburb
Avs air bag kit
I bought a full air bag kit from AVS. It came with the instruction on the wire and the air line , but not on the instillation of the bag and the brackets I have the fronts figured out but for the life of me can't get the backs. If anybody has done one of these can you reply with picture or point me toward the right way. Thanks in advance.
1970greenburb is offline   Reply With Quote
Old 01-06-2013, 01:24 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
Don't know what the kit would involve for the back. You can typically use the same bolt from the bottom of the trailing arm to bolt the bag to it. The top will take some drilling into the frame for you to line up the thread holes.
Take some pics of what you got and we'll know better about what you have.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-06-2013, 01:51 PM   #3
1970greenburb
Re: Avs air bag kit
Hey thanks Bryan I will take some picture of the brackets and post them maybe some one will know..
Russ
Old 01-06-2013, 02:17 PM   #4
Infanti
www.infantimachine.com
Infanti's Avatar
Re: Avs air bag kit
Give Jeff a call at AVS im sure he will help you out.
AVS
1489 N THESTA ST
FRESNO, CA 93703
M - (559)492-6773
P - (559)486-5444
F - (559)486-5155
www.airbagparts.com
facebook.com/avsontheweb2
Manufacture of Filler Panels
Billet washers
Infanti is offline   Reply With Quote
Old 01-06-2013, 03:54 PM   #5
1970greenburb
Re: Avs air bag kit
Thanks Infanti I bought the kit from Gordon there I will give Jeff a call Monday ..
Old 01-06-2013, 04:18 PM   #6
1970greenburb
Re: Avs air bag kit
Posted via Mobile Device. Here is one bracket I am thinking this one goes on the frame?
Old 01-06-2013, 04:21 PM   #7
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
Yes, it must. I've never used an upper bracket. I just align the bolt holes, measured, drilled and bolted them to the frame. I'm assuming you can do that with that also, but don't know why you'd need that between the frame and the bag.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:28 PM   #8
1970greenburb
Re: Avs air bag kit
Posted via Mobile Device Here is the cups there are two of these and two that are shorter, these have the holes for the air fitting to come through. But how would these mount and stay on frame or trailing arms.
Old 01-06-2013, 04:30 PM   #9
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
I really don't think you need brackets for the rear. I'm guessing you bought a universal kit and you won't need everything in your kit.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:31 PM   #10
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
The shorter one is probably the front. Also, to get the front a little lower you can shave 5/8 of an inch off of the cup and then put it in.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:36 PM   #11
1970greenburb
Re: Avs air bag kit
Posted via Mobile Device This is a side view on the first bracket. It fits the frame good, but it does not allow the air bag to be mounted where the air fitting is on top.
Old 01-06-2013, 04:37 PM   #12
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
Does your bags have studs coming out of them or are threaded into them?
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:43 PM   #13
1970greenburb
Re: Avs air bag kit
Old 01-06-2013, 04:44 PM   #14
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
That's the bottom that bolts to the trailing arm.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:48 PM   #15
1970greenburb
Re: Avs air bag kit
Posted via Mobile Device Would you drill hole in frame big enough for the fitting to go through or maybe use that bracket and drill that out for.
Old 01-06-2013, 04:49 PM   #16
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
Probably just use the bracket as a template of where to drill.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:50 PM   #17
1970greenburb
Re: Avs air bag kit
So you just use the center hole and use a 3/8 bolt and go up through the trailing arm?
Old 01-06-2013, 04:53 PM   #18
1970greenburb
Re: Avs air bag kit
The fitting will go just right beside the frame? Have not tried that yet, I was thinking I was going to be using the brackets.
Old 01-06-2013, 04:55 PM   #19
5150
C10 Club Tennessee
5150's Avatar
Re: Avs air bag kit
Yes, just use the center hole. You might be able to position it where you don't need to drill a hole for the air line.
Bryan
www.gmtruckshow.com
Old 01-06-2013, 04:58 PM   #20
1970greenburb
Re: Avs air bag kit
Old 01-06-2013, 05:00 PM   #21
1970greenburb
Re: Avs air bag kit
I think I am on the right track now Thanks a lot 5150 heading out to the garage to try it right now..
Thanks again Russ
Old 01-06-2013, 05:01 PM   #22
1970greenburb
Re: Avs air bag kit
Ok sounds goods.
