Old 01-07-2013, 09:10 PM   #1
Ridgeclimber
Ls 4.8/4l60e question?
I've started to get my 1968 short box step side ready for the Ls 4.8/4l60e swap. I removed the old six cylinder and three speed trani, cross member, shifter linkage. The only question I just thought of will a 4l60e trani fit with a low hump floor? I ordered the early classic engine and trani mount kit to mount the engine and trani. Thanks for any advice.
Ridgeclimber is offline   Reply With Quote
Old 01-07-2013, 09:19 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Ls 4.8/4l60e question?
Yes it will clear
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-07-2013, 10:07 PM   #3
mcbassin
Still Learning
mcbassin's Avatar
It really depends on how far back you tuck your engine. If you move it as far back as I did it will hit the low jump. You can get motor mounts that will let clear( I think). Check out the ls swap section, there are some threads on this subject
Old 01-08-2013, 08:37 AM   #4
68Stepbed
68Stepbed's Avatar
I put my LS1/700R4 in the rearward 6-cyl position. It's a tight fit, but it does clear.
BTW the 4L60E and 700R4/4L60 are basically the same.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
