Old 01-08-2013, 01:45 PM   #1
CCCC
CCCC's Avatar
Lengthening a C30 157" frame
Need some "how to" info. Am ready to do an odd project - converting a very low-mileage 72 C30 chassis mount MoHome to a cab+sleeper+long bed 5th wheel hauler. Looks like I need an additonal 24 to 30 inches of wheelbase length to make it work nicely. Anyone know if this is feasible and where and how best to make the insert - or know of any threads that tell/show how best to do this. Any help appreciated.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 01-08-2013, 03:18 PM   #2
SS Tim
SS Tim's Avatar
Re: Lengthening a C30 157" frame
Just to clarify.
You have an existing 157" and you want to strech it to 181-187"? What bed are you wanting to use, an 8' or 8 1/2' longhorn bed?
A stock 157" will give you 30" between the cab and an 8' bed.
Been playing around with a 10' bed concept on a 157" with the rear bobbed to SWB overhang (8.14"). Though it might end up a 9' on a 145" due to California's definition of "pickup".
As to doing the mod. Everything I have found here has been on shortening. But many ramp trucks and some motorhomes were on extended chassis so hopefully someone can give use some pictures and fishplate sizing info.
Thinking that for what you want another chassis might be the best way to add the length. A section extendending forward from the carrier bearing on the added section to aft of the existing carrier bearing crossmember. Then you can run a three piece driveshaft with two stock sections. Remeber though a 133" is different from a 157". PM an email for this drawing that may be helpful to you.
The crewcab GMC pictured would be about a 166"wb.
C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
C20/30 133 (Longhorns) 7.20" height 2.77" flange width 0.194" thick 5.05 section modulus
C30 157 8.18" height 2.97" flange width 0.224" thick 7.29 section modulus
http://67-72chevytrucks.com/vboard/s...d.php?t=545240
SS Tim is offline   Reply With Quote
Old 01-08-2013, 03:21 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Hey There - if you had access to another C30 frame, you could cut two frames long and join those together instead of trying to splice an extension in the existing frame.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 01-08-2013, 05:59 PM   #4
CCCC
CCCC's Avatar
SS Tim - thanks - I appreciate your data. We basically are are on the same track. Current wheelbase is 157" and want to use an 8' bed - am thinking about at least 48" (interior) sleeper compartment behind the cab. Our thinking on added length is about the same, but my calcs only give me 27" from back of cab to front of 8' bed on the 157" base. I need to take another look/measure.
Have not ever seen such a MoHome on a longer chassis, but have seen two haulers like that - so - it has been done nicely. I just want to get it right by using someone's good experience. The aded driveshaft issue seems to bother me the most, so thanks for those observations.
Please chime in with anything else you think about, and please see PM on this.
Propanemudtruck - thanks. am looking for a junked C30/GM3500 frame. The other 1 tons here are too nice to tear up.
Anyone else out there?
CCCC
Old 01-08-2013, 07:28 PM   #5
CrewCab59
CrewCab59's Avatar
If don't care you could use a newer P30 step van frame build or transfer the body mounts over , most were 156wb and 186wb plus the extra 2 to 3 over hang. That way no worry about cutting the frame, just a thought.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-08-2013, 08:24 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
My 71 C30 Motorhome is a stock 157" stretched to 184"+/-. They butt welded a section of C30 frame and then put a piece of 1/4" plate half way inside the frame and spot welded that in. The plate is about 10" longer than the stretch.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-08-2013, 10:00 PM   #7
CCCC
CCCC's Avatar
Thanks - hope you can reply some more. This is good - since that altered WB is 184 -where did they cut and splice the frame?? What did they do to lengthen the drive shaft arrangement? Add another section with another carrier bearing or just universal joint, or lengthen one original section?
CCCC
Old 01-08-2013, 09:31 PM   #8
uncle
Gotta ramp truck that's about 200" wheelbase. Never driven it but will look and get apic or 2.
uncle is offline   Reply With Quote
Old 01-08-2013, 10:03 PM   #9
CCCC
CCCC's Avatar
Thanks. Wow - 200". I will appreciate anything you can send - pics or data on how it was done.
CCCC
Old 01-08-2013, 09:57 PM   #10
SS Tim
SS Tim's Avatar
OK, Glad to be of help.
Ran through the numbers and this is how I am getting a 30" gap on a 157"wb with an 8' bed (which actually measures 98" inside length and 102.23 overall length).
127" w/8'bed
133" w/8 1/2'bed, 6" longer bed forward of the rear axle (Longhorn)
157" - 127" = 30" wheelbase stretch/increase from rear of cab to bed front panel over stock gap.
The crewcab picture I posted earlier is probably a 169"wb.
Scott-Bilt crewcab is a 42" stretch as a point of reference.
Their frames were extended and fishplated
Here is 68 C30 178" wb ad link
http://67-72chevytrucks.com/vboard/c...l-texas&cat=12
Old 01-08-2013, 10:31 PM   #11
CCCC
CCCC's Avatar
SS Tim - thanks for your interest and info. It is clear how you are getting the 30" gap.
I have been using somewhat crude measurements (quickly today, out in a freezing garage) and got front of 8' bed to middle of rear wheel at 60" and back of cab to middle of front wheel at 73" for a total of 133" and a resulting gap of only 24". So, there is a 6" difference in our calcs, and am figuring that you are more on the mark - which would be good because I would need to add a bit less splice. I will get that nailed exactly on this truck.
The data on other conversions etc, is helpful and the info from some other guys here is also interesting - like using a "P" frame - but I want to try to keep this project as simple as possible so don't want to move this rather cherry cab and drive line.
I need to find part or all of a C30 frame and, looks like, some drive shaft stuff. I live very remote, so finding old stuff is hard - it's many miles away. Maybe I need to get that one in OK. Oh well, it's only time and $$, right?
Thanks again.
CCCC
Old 01-09-2013, 12:26 AM   #12
PAWS 72
PAWS 72's Avatar
google big truck sleeper and call a couple of them. the will give you the lenght of splice that you will have to have.
There is several guys that haul campers that has them on their 3/4&1 ton trucks. I wanted one but never did have 1 installed. $6500.00 for a new one the last time I called about 3 years ago.
I found a 48'' sleeper last year i should have bought.It came off a friend's big truck when it got rolled on the side.
PAWS 72 is offline   Reply With Quote
Old 01-09-2013, 12:28 AM   #13
SCHRUMGMC
SCHRUMGMC's Avatar
Them Extended things look weird to me LOL
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-09-2013, 12:37 AM   #14
PAWS 72
PAWS 72's Avatar
had to switch puter. Check these out.The Ford,The guy paid close to $30,000.00 for it installed in Shipshewana, Indiana. It's an 8' condo for big trucks.The fuel mileage changed by 3 mpg.I used to see the guy alot when I was going up there.
I would tell a story about me and him coming home one nite but this isnt' the thread.Highspeed thru Montgomery ala. The other I talked to the guy some on the yard. Never did see a Chevy tho.
Old 01-09-2013, 02:57 PM   #15
OldCreek
OldCreek's Avatar
I suppose you could add the length to the rear of your frame and slide the axle back. You will have to move the leaf spring mounts, etc. The 4x4 guys do it all the time...not too difficult at all (if you like removing rivets!).
You will, however, have to lengthen the drive line, e-brake cables, fuel line, brake lines, rear light lines..I'm sure you know all this. You're pinion angle may be off, also. Still, these are things you will have to do if you cut and splice the frame, too.
...Sounds like fun!
As SSTIM posts, the frame section is definately larger in the 157" wheelbase.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-09-2013, 11:46 PM   #16
CCCC
CCCC's Avatar
Originally Posted by OldCreek View Post
I suppose you could add the length to the rear of your frame and slide the axle back. You will have to move the leaf spring mounts, etc. The 4x4 guys do it all the time...not too difficult at all (if you like removing rivets!). You will, however, have to lengthen the drive line, e-brake cables, fuel line, brake lines, rear light lines..I'm sure you know all this. You're pinion angle may be off, also. Still, these are things you will have to do if you cut and splice the frame, too. ...Sounds like fun! As SSTIM posts, the frame section is definately larger in the 157" wheelbase.
Good observations - and - due to the MoHome configuration, that frame already has been extended further behind the rear axle, so I do have the frame capacity back there. But, as you note, it's a pain (for me, anyway) to bust rivets and move the entire axle assembly - not going to do that - and, enough other stuff to extend already. Have yet to decide between pickup bed or flat bed back there - but the flat bed config would make things quite a bit simpler. Size of sleeper is in the mix as well. Must make some decisions because I want to move it out and get the project started in less than 2 weeks. But, as you said, it is fun.
CCCC
Old 01-09-2013, 05:55 PM   #17
SCHRUMGMC
SCHRUMGMC's Avatar
How in the world is these mutations even made?
1971 GMC Sierra
1959 GMC 100
Old 01-09-2013, 06:22 PM   #18
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Steel, a welder, and some imagination.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-09-2013, 07:05 PM   #19
SCHRUMGMC
SCHRUMGMC's Avatar
Do some of these come from Production ?
1971 GMC Sierra
1959 GMC 100
Old 01-09-2013, 08:58 PM   #20
72 tigger
72 tigger's Avatar
I built a 149" WB extended cab by using two chassis. That way there was just one splice. I would recommend cutting the frame in a Z pattern, instead of a butt splice (a 1/4" fish plate on the inside is a good idea also). A drivetrain shop should be able to help with the driveshaft problem.
72 tigger is offline   Reply With Quote
Old 01-09-2013, 10:09 PM   #21
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Only production would be from a fab shop or conversion shop. These are popular with hot shotters for the most part.
Ryan
1969 Chevy milk truck
Old 01-09-2013, 11:09 PM   #22
SCHRUMGMC
SCHRUMGMC's Avatar
Oh okay, I have never seen anything like it !! LOL..
1971 GMC Sierra
1959 GMC 100
Old 01-10-2013, 10:54 AM   #23
brad_man_72
the boat guy
brad_man_72's Avatar
I build driveshafts for a living, I've built thousands for 10' stretch limos, and other assorted stuff. Unless you like moving crossmembers around id add the frame lenght between the trans and first carrier mount. That way the driveline shop only needs to build one carrier shaft. The driveline shop will need to ballance all 3 shafts together in one ballancer, if they can't do that take it somewhere else.
We work with quite a few big rig shops/rebuilders and limo builders, from what I hear some of the big rig shops charge next to nothing to lenghten a frame, and have a good working relationship with a driveline shop. They will also be able to rivet anything back together so it looks factory. This may be a good cheap and fast option!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-10-2013, 06:25 PM   #24
CCCC
CCCC's Avatar
brad_man, this is very helpful info. The drive shaft insight is excellent. Have not yet decided whether or not to lengthen the frame and don't live anywhere near a big rig shop, but can get to one if needed.
CCCC
Old 01-10-2013, 07:36 PM   #25
uncle
Can't tell if 2 frames or stretched but is 200" wb. It's plated from back of cab and goes about 4ft. May be able to see in 1st pic. It also has extension in rear. Has one stock x-mem and one added so it has 3 pc. shaft. Here's a couple pics.
