Old 01-09-2013, 11:10 PM   #1
paintpyro
paintpyro's Avatar
Master cylinder threads
So swapping to power disks, McGaughy m/c. Easiest way to get rid of these threads? I'm not a small guy. It's tight under the dash to get in there to ditch the welds holding em in place.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 01-09-2013, 11:53 PM   #2
Razor454
Razor454's Avatar
Re: Master cylinder threads
Are you sure yours are welded? I was able to pop mine out using a dead blow hammer in my 67.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 01-10-2013, 11:37 AM   #3
paintpyro
paintpyro's Avatar
May be another 'gift' from my previous owner. He was terrible with a torch. Underneath the dash, where the base tightens up against the bracket, there are welds on all four studs.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 01-10-2013, 01:41 PM   #4
70blackfish
cut flush, with cut off wheel
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-10-2013, 08:45 PM   #5
Razor454
Razor454's Avatar
I hate to say it then, but your going to have to cut the welds and then pound them out to do it "right".
Old 01-11-2013, 12:29 AM   #6
Chvy2NV
Aren't these bolts used for the new setup?
Chvy2NV is offline   Reply With Quote
Old 01-11-2013, 12:53 AM   #7
paintpyro
paintpyro's Avatar
The new power master cylinder has the threads coming from the booster, so the bolts will tighten from the firewall side.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 01-11-2013, 02:53 AM   #8
First c10
First c10's Avatar
Did you get rid of the stand off bracket that has the pivot to raise the booster? I am not if you can do that can you? I am changing my booster tomorrow and am not sure if the 4 studs from the booster are even the same as the 4 sticking out of the firewall I am interested in seeing your set up
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-11-2013, 03:30 AM   #9
paintpyro
paintpyro's Avatar
I've seen pictures with the standoff bracket removed. The holes on the standoff don't align. I'll try to post up pictures.
"Schleprock"
350 w/TH400
rallys and BFGs
