Whats this?????
Well while I was getting ready to clean up the starter wiring. (FUN TIMES)
![]() Thanks Everyone Last edited by Zable49; 01-11-2013 at 09:44 PM. |
Re: Whats this?????
reverse light switch possibly?
Re: Whats this?????
Re: Whats this?????
if it is original tranny probally the TCS thingy that was an early polution control thingy that did not much in real life/// backup light switch was combined with NSS on the steering column
![]() Join Date: Sep 2000
Re: Whats this?????
I agree with cdowns my truck had the tsc I took the sensor out becouse it leked still have the wires tied back.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Re: Whats this?????
What transmission? If I remember correctly, and may be wrong with this cause it may only be Corvettes but... is that maybe where the solenoid for the passing gear goes?
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Whats this?????
Correctamundo Beetle! That option was offered exclusively for the Corvettes and the elusive Factory COPO Trucks! You've single offhandedly discovered the "missing COPO link!"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#8 | |
Re: Whats this?????
Cluster King
![]() Join Date: Nov 2012
Re: Whats this?????
Jason you are correct. It is the electric kick down for a 400 transmission. If truck came factory with a 400, there should be a switch on the top of the gas peddle inside the cab.
#10 | |
Re: Whats this?????
Re: Whats this?????
My Turbo 350 has the same thing though...
71 K20 64 GMC mud truck |
Re: Whats this?????
It's for the TCS (transmission controlled spark), it also used a couple of relays on the firewall and a solenoid on the intake that had the vacuum advance hose run through it so it could adjust the amount of advance in high gear. As said earlier, it probably didn't work real well when new, and even less now days.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#13 | |
Re: Whats this?????
http://www.67-72chevytrucks.com/vboa...d.php?t=558016
-Scott- Last edited by sjarrett71; 01-12-2013 at 10:35 AM. |
Re: Whats this?????
Cool, thanks guys. I think I will just remove it and block it off so I dont run the chance of it leaking down the line.
