Old 01-13-2013, 10:44 PM   #1
Sanchez Garage
c5 brakes into a 63
Is there any way of putting a c5 caliper set up front with out having to buy control arms? Can a bracket be made or sold already to use with a hub? If so who make them.
Sanchez Garage is offline   Reply With Quote
Old 01-13-2013, 11:42 PM   #2
andrewmp6
Re: c5 brakes into a 63
Only way i know is to do a 73-87 spindle swap and a kit like http://67-72chevytrucks.com/vboard/s...d.php?t=390979 or something close to it http://www.mcgaughys.com/bigbrake.html those brakes are 13 inch rotors 2 piston calipers which is about what the standard c5 brakes are.Or check out http://www.abspowerbrake.com they have a few brake options for your truck too.Or another place http://www.classicperform.com/
Old 01-14-2013, 12:45 PM   #3
CHYNSPR
Try kore3.com
1972 Cheyenne (LWB now a SWB)
CHYNSPR is offline   Reply With Quote
Old 01-14-2013, 10:59 PM   #4
Sanchez Garage
Yeh, I think I will give Tobin a call. I got to order some hoses. I just wanted to see if any had made some brackets with a hub type set up instead of buying a set up.
Old 01-14-2013, 11:18 PM   #5
jimmydean
jimmydean's Avatar
This.
http://67-72chevytrucks.com/vboard/s...d.php?t=465140
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-16-2013, 06:09 PM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by jimmydean View Post
I got this set from Boris. He was great to work with. He uses a spindle from McGaughy's. I got a set for an '82. For your '63, it would just be a simple ball joint change and an adapter for the outer tie rods. I bet he could do a set that would bolt up without any changes....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
