Does this look right 1985 pinion shaft?
Hi
First time posting, long time lurker. Wish I could help out more but I don't know anything. With your guy's help I've been able to fix many things on my old 1985 GMC step side. Thanks. I decided to open up the rear differential to change the oil and found a surprise waiting for me metal shavings in the fluid. The pinion shaft lock bolt was broken. I was able to order a new one as well as a new cover. I've searched for the correct install for this pin but couldn't find what I was looking for. Does this look right? I can't find a hole in the pinion shaft for the lock bolt Thanks Kyle |
Re: Does this look right 1985 pinion shaft?
my money pit!
Sorry to say but that hole should not be oval. Your rear is shot. It needs to be rebuilt or replaced. No way around that :/
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Well I was hoping for the best and got what I had thought. Didn't think it was possible to wear that much. Most of the pictures i've seen the hole was round and didn't want to believe it had worn that much. This might be the last straw for this truck. Time to start looking for a better side step with AC and less headaches. Thought I had got a good deal paying 1600 bucks for this truck. I guess it was to true to be good. At least the 305 engine is in good condition I should be able to salvage it. Thanks.
It still is a good deal. You can simply go to a wrecking yard and get a whole new rear. It's like $125 here for me. I've done it and so have a few freinds of mine. When that center pin gets worn it rocks back and forth and wears a grove and often breaks.
Remember these trucks are in thier 20s at least not a lot of easy miles on most. Fixing the wear areas makes a big difference. It's mainly the drivetrain and then the suspension in that order to worry about. Nobody said fixing cars and trucks was easy and that's not really why we do it. Just take the good and bad in stride and it will be there for you always Posted via Mobile Device
![]() Join Date: Oct 2011
I agree. Don't get rid of the truck because of that. Go to the bone yard and pick up another one or get a new carrier and rebuild it. (or have it rebuilt if your not comfortable with diff's)
Moderator
![]() Join Date: Oct 2008
Go to a yard and get another 1/2 ton axle. They're cheap, plentiful, and pretty easy to swap.
Look for one off a truck without a trailer hitch. You can pull the diff cover before you yank it or ask the yard ducks to pull the cover off one they pulled... Just to make sure there aren't any surprises like the one you just got.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
also by pulling the cover you might want to check to have the same ratio, at least if you dont want to change it, to give you less work....
If you dont want to go that route go to a parts store and buy the spider gears. They have a kit to replace all four spider gears. Usually less than 75 bucks.
Posted via Mobile Device |
#10 | |
Okay so my options are
1. nothing just put it back together and drive. It was running fine. 2. Can i just replace the carrier? this seems like the easiest route. I wouldn't have to take the axle off? 3. replace the whole axle. I'm leaning to just putting it back together for now and fix when it's warmer. should I leave the pinion lock bolt in or take it out? regular 80-90 weight differential fluid okay? Thanks guys couldn't do it with out all the help. Kyle |
#12 | |
Putting a new center pin in with those groves means that the entire vehicles weight is on those bolts. They will fail and the spider gears will bind and lock up your wheels. Hopefully in your driveway and not the highway. I'm surprised it hasn't yet Posted via Mobile Device
I have detonated rear ends that look a lot better than that. Hard to believe that it hasn't let go yet. I wouldn't drive it. It's just a wrecker ride waiting to happen.
#14 | |
The advantage of finding one at a junkyard, the gears are already set up so you don't have to fool with them. To re-do gears, or set up a new carrier means you have to add/subtract shims, re-do your pinion crush sleeve, etc. Junkyard is your best bang for buck. If it was my truck, I definitely would NOT drive it in it's current condition. I just don't think it's safe. So don't fool yourself it's OK to just put back together and ignore. This is not one of those options.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
#15 |
Yep, as said above, junkyard. Measure your WMS to WMS to be sure you find the correct width when you get to the junkyard. Also, look at the numbers on your existing ring and match those. You should see something like 41 - 11 (3.73 gears) or 41 - 12 (3.42).
Also, just double check the spring perch measurements but they should be the same unless you look at a 1 ton..... Used axles are $100 here. Also, pay attention to 5 lug or 6 lug (yours looks like a 2wd)
