problems with bellhousing bolts
'81 K10 350, sm465
i'm doing a clutch and flywheel job, or trying to rather, all i have left to disconnect is the bellhousing from the block, i've got the lower 2 bolts off of the right side as well as the lower 2 off on the left side, but i can't get the top 2 bolts off. my dad who used to work in a shop said that they always used to use extensions and swivels to get them off, i tried that with both a ratchet as well as a impact, but i cant get enough torque with the ratchet or breaker bar, and the impact isn't working either, i've tried from the top with a wrench and a bar and i can't get that either. this is my daily driver, i'm borrowing a car from a friend for the time being but i need this back on the road asap!!!! anybody got any tips or tricks? I know you do, YOU GUYS KNOW EVERYTHING!!!!! ![]() thanks in advance guys
I used to be a ford man... then i learned a thing or two -81 K10 350, DD, will be mildly modified... eventually |
78K & 79C Jimmys
Re: problems with bellhousing bolts
some trucks seem closer to the firewall
but i use 2 wrenchs if it's a tight fit one on it the other,2nd box end 90 degress to the the first,sits in the open end hard to explain.... ive even seen holes drilled and rubber caps used!
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Sounds like you are trying all the right things; swivels and breaker bars from the bottom or wrenches from the top.
I'd try those again with more leverage (aka "cheater pipes"- pieces of black pipe slipped over the end of the breaker bar) - or - go with drilling holes through the firewall and plugging later, as Motornut has suggested. Try to keep those swivels as straight as possible (minimize the angle). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-14-2013 at 11:16 AM. |
when i used the wrench i did use that 2 wrench trick, im soaking them in pb blaster now, in hopes that will help, and i have been trying to keep the swivel as straight as possible, good to know that theres nothing major i'm missing, makes me feel like less of an idiot haha
i was thinking about picking up one of these from harbor freight, it comes with a 14mm wrench end, which is the same size as the 9/16" i need, i think it ought to help a good bit
I made a piece of flat bar and bent it just a bit and used some hose clamps to hold the wrench onto it to make a longer wrench and got the bolt off from up top
At the body shop.
3/8 impact wobble 18" extension with a 1/2 end . And go to work
" That didnt make it any newer " " Dont antique the equipment " |
I built a long wrench to get them from the top. Welded a 9/16 box end to a 12" -1/4x1" flat bar then "custom" bent the wrench end. Works every time... Otherwise an 18" extension and swivel with a shallow socket is my next choice (like the other guys said).
hmm i'll have to try the extension and swivel trick again, i was using more than 18" of extensions though, maybe it will work better with only 18" worth
Put one of your bolts that you removed back in. Lower your trans cross member so you can get closer to the top bolts with the engine/trans tilted down. Use a shorter and thicker extension.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
#11 | |
thanks for all the help guys, ive found this to be a more helpful forum than any other forum i've been a part of ![]()
#12 | |
One thing that has worked for me is getting your wrench on there and then smacking it with a big hammer, sometimes the sudden blow will loosen the bolt.
![]() 1985 C10 2004 Avalanche |
A tip for you guys!
If you have trouble with your swivel flopping around making it hard to get the socket on the bolt try this. Wrap some black electrical tape around the joint. Makes it more manageable especially when reaching into tight spots. |
Yup. This old trick works great.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
#15 |
let the back of the motor down until the dist almost touches the firewall, then you can use a couple extension to get to it, if that doesnt work i have gotten to the from the top with a ratchet wrench
#16 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Also, long extensions soak up torque and multiple extensions stacked onto each other do too. This is one case where a single, long, high quality extension is worth the money. I've got a set of fat SnapOns that have taken bolts off where cheaper ones just sat there and hammered without budging them. |
#17 |
does the floor around the shifter come out? if it does,you can go in that way with an impact.
#18 |
i got it guys, i knew i needed to eliminate the swivel in the first place but didn't know how, once i dropped the trans/xfer case (had the fiance watch to make sure i didn't run the dist. into the firewall) and from there it was a straight shot and just used a extension a ratchet and a cheater pipe, came off pretty easy, thanks guys!!!!!! got everything out and just gotta pull apart the flywheel pressure plate etc etc, then just do everything again backwards
#19 |
![]() Join Date: Apr 2009
On my engine swap , I just removed the center floor panel and shifter boot , and they were right there staring at me.
Desert |
