01-14-2013, 05:47 PM | #1 |
Auto Column rebuild questions
Anyone know if this steering shaft setup comes apart any further? Id like to clean it all up and re-lube it. Its pretty grimy. It looks like it may have been pressed on?
Also does anyone know where to source the lower bearing? |
01-16-2013, 01:15 PM | #2 |
Re: Auto Column rebuild questions
looks like it can be torn down some more, but you might be able to clean from where you are at now, you can buy the upper and lower bearings off one of the venders here on the forum ,we have some good one's, just go to the venders site and click on the one you want and look at their stock...if that one don't have them the next one will..
01-16-2013, 01:30 PM | #3 |
take it apart at the top by steering wheel when you take it apart the top you can pull the shaft out and the other end will pull out also
01-16-2013, 05:40 PM | #4 |
Its not supposed to be taken apart any further then that. You can clean it & lube it so the lever slids up & down.
