![]() Join Date: Apr 2011
Interior and exterior trim differences
This past weekend I pulled all the pillar trim and exterior cab band from what I think was an '87 Sierra Classic..or so says the dash and emissions sticker, as the doors were not the originals and no fender emblems.
Anyway, I pulled the trim thinking I can use it on my '80 GMC project. I looked up on LMC and it looks like all but the A-pillar trim will work - whats the difference there? They don't list a '73-80 pillar trim, did those trucks not come with A-pillar trim? Will the '87 work in mine? My truck is just a plain Sierra so I'm gonna be drilling into the cab anyway...all the screws I pulled were sheetmetal screws so I assume thats how it was done in the factory. Regarding the exterior trim, again going by LMC, the exterior cab band looks to be different '81-'87...again what gives? Can I install the '87 cab band on the '80? Truck doesn't have cab molding clips so if I were to install the '87 band, I would buy the clips for an '87. I know it will not necessarily be period-correct, but to the untrained eye, is it gonna matter? There are other parts of the truck that aren't "period correct" ![]()
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
Re: Interior and exterior trim differences
Fron my experiece it won't work, like the dash pad's. almost look the same... But they're not. My 79 origional can had it nut my 78 doesn't... I like it.
Posted via Mobile Device |
The cab bands are definitely different. I've been looking for an 80's GMC cab band for mine, but ended up buying a 73-80 style. You can use either one, the cabs were the same. If you're starting with nothing, it will work. You can't use the 80's cab band on the 70's clips and vise versa. The A-pillar trim won't work, as the dash pads were different.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
I spend about 200 dollars on interior parts, waited until a nice weekend... And ended up just grtting aggrivated. Really wished i done my research first.
#5 | |||
Would the A-pillar trim work if I trimmed them perhaps? I don't want to go needlessly hacking if there's no shot of it ever working or looking nice... Quote:
Im sure you can probably make the trim work, although the A pillar trim did exist in the 70's; it just isn't listed in LMC. Keep searching, you'll find the right stuff. And yes, use the 81-87 clips for the cab band.
78K & 79C Jimmys
when you say A pillar trim you mean dash pad to visor,right?
you can use the jimmy /blazer ones? white my 88 pad 79 trim
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
