01-15-2013, 08:53 PM | #1 |
Cutting coils, tire clearence issues?
I was considering cutting a coil out if i remember correctly thats 2 1/2" roughly per coil. I am running 30x9.50 R15 tires, does anyone know if i would have any clearance issues? its still at stock height
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
01-15-2013, 09:11 PM | #2 |
Re: Cutting coils, tire clearence issues?
if you only cut off one round you will have no problems at all.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-15-2013, 09:25 PM | #3 |
Thanks Ghetto i suspected but never done it and wanted to make sure.
01-15-2013, 09:30 PM | #4 |
no problem
01-15-2013, 10:23 PM | #5 |
I've thought about cutting the coils on mine for now as well. Does anyone know if you can still get a good front end alignment if you cut them?
01-15-2013, 10:33 PM | #6 |
At the body shop.
depends on how much stud is available.
" That didnt make it any newer " " Dont antique the equipment " |
01-15-2013, 10:36 PM | #7 |
Alright, I've also found these springs, that are suppose to give you a 3 inch drop.
http://www.summitracing.com/parts/sum-g726 Would I be better off going with these? |
01-15-2013, 10:46 PM | #8 |
why dont you just do it correctly? put spindles on it so it keeps the same suspension and steering geometry and the ride isnt rough
01-15-2013, 10:49 PM | #9 |
I'm not too worried about the ride being rough. And at first I was planning on doing spindles and all, but I've decided I don't want to sink a lot of money into this truck like I have on others in the past.
01-16-2013, 01:40 AM | #10 |
the ride wont be rough, the half ton spring even with 2 coils cut are still squishy little noodles. i got my neg camber where i wanted with room to spare after 2 coils. i have 29" tire and i rub pretty hard some times. i wouldnt do more then 1.5 coils with 30" tires and half ton coils
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-16-2013, 10:34 AM | #11 | |
01-15-2013, 11:12 PM | #12 |
There is nothing wrong with cutting a coil. You should be fine on alignment. I always do that before ordering lowering springs. Most of the time I'm happy with the ride, and I'm picky. Just make sure the rest of your suspension is in good shape.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-15-2013, 11:13 PM | #13 |
It followed me home?
^^^^ x2
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-16-2013, 12:41 AM | #14 |
Cutting 1 coil would not be a problem. Cutting more than that creates problems. And yes you can still get a wheel alignment afterwards. After I installed my drop spindles I had a hard time finding a place to get an alignment. Nobody wanted to do it for different reasons.
Posted via Mobile Device |
01-16-2013, 02:13 AM | #15 |
At the body shop.
I've always clipped 2 coils from 1 ton springs for my 1/2 ton drops. Put longer bolts in the upper A arms. And cut the bumpstop pad off.
Flipped the rear. Wrong maybe... works for me. Posted via Mobile Device
