01-18-2013, 11:30 AM | #1 |
Shorting mirror arm
I want to cut 2-3" off the outside mirror arm and go from the stock 5" round to a 3 to 4" round mirror head. Before I start cutting I thought I would ask to see if anyone has done this and could post some pictures.
Thanks for the help |
01-18-2013, 12:13 PM | #2 |
Re: Shorting mirror arm
Why not get a short 60-61 cast iron mirror arm which is 2" shorter. The 62-66 arms are hollow and the 60-61 are solid.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-18-2013, 12:20 PM | #3 |
Would a shorter arm clear the vent window on a 64-66? I've thought of doing this on my '66.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-18-2013, 12:44 PM | #4 |
hmmm...not sure. Never put one on a 64-66 door. But if it clears for a standard arm, I would think it would for an arm that 2" shorter. Especially is running the factory mirrors w/the bottom stud. It allows the mirror to be adjusted out different than the aftermarket mirrors w/the center studs. I could mail on edown to check if needed though. I have a short arm left.
01-18-2013, 12:47 PM | #5 |
Just cut it and weld it back together
01-18-2013, 01:12 PM | #6 |
Check The Champ, Demonstrator
It's been done by a member on this site. Orange truck, painted bumpers, can't remember his Avatar.
01-18-2013, 04:42 PM | #7 |
Senior Enthusiast
It could also be easily done with JB Weld if you could find a piece of smaller tube that was a slip fit inside. Just section the outer tube with a tubing cutter, slip the pieces together with a glob of epoxy, and wipe/sand the outside of the seam when it dries.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
01-18-2013, 11:59 PM | #8 |
I did mine. I have one peace glass so the mirror arm doesn't have to be long hope this helps
Jim |
01-19-2013, 09:58 AM | #9 |
01-22-2013, 09:37 PM | #10 |
01-19-2013, 08:56 PM | #11 |
I did my old 64.
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
