01-18-2013, 01:50 PM | #1 |
Removing and Replacing Doors
I need to remove my doors so that I can drill holes for a power window install.
Is there any tricks or anything that I should know about the reinstallation process? I'm a carpenter and have installed a thousand doors but I never touched one on a truck before. Thanks for the help guys. |
01-18-2013, 07:54 PM | #2 |
Re: Removing and Replacing Doors
If you are looking to do something as far a re aligning the doors oncethe holes are drilled, take an 1/8 drill bit and drill through the hinge and jamb. Thay way when you reset the doors. all you need to do is to put a bit in the hole and tighten the bolts.
01-19-2013, 01:44 AM | #3 | |
Home Built '87
Plus there is a bolt that goes under/through the dash out the sides to help hold the hinges onto the cab....can be fun trying to get to it sometimes.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
