01-21-2013, 12:41 PM | #1 |
c notches what are these?
What are c notches and what do they do? I'm looking at buying a drop kit that comes with bolt in c notches just wondering if I have to do anythibg special to truck.
Posted via Mobile Device |
01-21-2013, 12:48 PM | #2 |
67-72 parts collector,…
Re: c notches what are these?
They add clearance in your frame directly above the rearend's axle tube.
(to allow for more drop)
01-21-2013, 01:38 PM | #3 |
you have to cut or "notch" your frame for that
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
01-21-2013, 11:58 PM | #4 |
Basically this
~When In Doubt Go Lower~ |
01-22-2013, 12:54 AM | #5 |
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
01-22-2013, 01:05 AM | #6 |
that's a z'd frame...this is a c notch...
01-22-2013, 02:17 AM | #7 |
That's not a z'd frame, a z'd frame is when the front of the frame just in front of the cab is cut and raised then rewelded effectively allowing the front to tuck more and the truck to sit lower. The z is in reference to the shape the frame where cut and rewelded resembles.
01-22-2013, 07:48 AM | #8 |
01-22-2013, 11:54 AM | #9 |
Happy to be here
Correct answer. The first notch pictured is referred to as a "step notch" not a Z'ed frame. The small notch posted by Pro Performance is a bolt in "C-notch" which is common to most average size lowering kits.
01-22-2013, 01:16 AM | #10 |
Here is a c-notch installed on an earlier frame.
01-22-2013, 02:33 AM | #11 |
A c notch is small its called that because the cut out looks like the letter c,Those are step notches its bigger brother.A z'd frame is a fully different animal then any kinda notch.
02-23-2013, 12:25 AM | #12 |
oh my bad...guess I just learned something new
