Before and After
Would I be able to put 1/2 ton springs in my C20 without any other modification?
I know that I wont have the load capacity, but I don't care about that. ![]()
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
![]() Join Date: Mar 2000
Yes you can, the heavy duty 1/2 ton spring is exactly the same spring as a 3/4 ton in all aspects as they shared the same spring, so be sure you get a standard 1/2 ton spring and not a heavy duty, only difference in heavy duty & standard rear springs are the max weight ratings.
GMCPaul |
Before and After
Is that for the front or rear or both?
