01-23-2013, 09:59 PM | #1 |
Where to buy pre-made vacuum line for th350?
Where can i buy a pre-made steel line for a th350 vacuum modulator to intake manifold? Or if i can get a hose, what is the best kind to use that wont suck in with the vacuum? Thanks
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
01-23-2013, 10:05 PM | #2 |
Cluster King
Re: Where to buy pre-made vacuum line for th350?
I am not sure if it is an aftermarket item or not. Any Chevy with a 350 trans, car or truck will have this line. You may have to tweak the end near the intake to line up with the fitting in the intakeor use a longer peice of rubber hose to connect. I would check out some local salvage yards or cars/trucks for parts on craigslist. I would not use rubber hose myself, just a personal thing. I think it is 3/16 inside diameter. You can also buy steel line at the parts store and cut and bend it yourself if all else fails.
01-23-2013, 10:10 PM | #3 |
Ordinary steel brake line will work with rubber ends and can be bent easy enough. I've used the larger dia stuff without issue.
Posted via Mobile Device |
01-23-2013, 10:22 PM | #4 |
Go online to www.LMCTrucks.com and I beleive you can get in Stainless or Reg.
01-23-2013, 10:49 PM | #5 |
I used 3/16 brake line and bent my own. Wasn't to hard to do.
01-23-2013, 11:52 PM | #6 |
Thx for all the responses
01-24-2013, 12:00 AM | #7 |
Try The Right Stuff. Here are links:
1972 http://www.getdiscbrakes.com/ttv7201 1969-1970 http://www.getdiscbrakes.com/ttv6905 I don't see any listed on their website for 1971, 1968 and 1967. |
