01-24-2013, 10:28 AM | #1 |
Removing Drive shaft loop cross member - 1972 C10
Getting to the final stages of the Porterbuilt dropmember rear install and I am not sure about removing the drive shaft loop cross member?
Going to cut a small arc in the back of the cab for drive shaft clearance and need to remove this cross member. Will removing this cross member cause the frame to become weak or twist? Thanks......... |
01-24-2013, 10:43 AM | #2 |
Re: Removing Drive shaft loop cross member - 1972 C10
Here is some Pics.
01-24-2013, 03:13 PM | #3 |
Junior Member
You mean the crossmember that the trailing arms attach to? That's the only one I can think that the driveshaft goes thru. Is this a trick question? Yea, pretty important piece. How did you get this far?
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
01-24-2013, 04:36 PM | #4 |
Thanks for the help jack off. This is meant to be a helpful forum and all you can do is be as non helpful as possible.
Sounds like you are one if those forum wanna be ass clowns that has nothing and is jealous of everyone else. Hope you have a great FN life jack off. Posted via Mobile Device |
01-24-2013, 05:00 PM | #5 |
Florida Edition
Yes, you need that crossmember, ties the frame rails together. If you are keeping the trailing arms you have to have something to attach them to. If not stock then a custom crossmember.
A bit of advice here....if you get a responce you don't like or p.o's you, ignore it and move on, someone here will help you. Responding like you did and your stay here will be short lived. Trust me.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-24-2013, 05:11 PM | #6 |
18 Till I Die
Even if you didnt need the trailing arm mounts anymore. I would leave it in for strenght. Its a nice beefy piece.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
01-24-2013, 05:12 PM | #7 | |
It'll Buff Out!
It was a question I had to read twice, and thats a good looking project. How about giving Nate a call @ Porterbuilt? I know he makes a new crossmember, maybe thats what you need for your project? If not i'm sure he could steer you in the right direction.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
01-24-2013, 06:28 PM | #8 | |
Catchy title goes here..
01-24-2013, 06:41 PM | #9 |
Florida Edition
Looking forward to seeing more of your truck here. I think you'll be fine, just be polite and you'll be treated the same.
01-24-2013, 05:12 PM | #10 |
Not trying to cause trouble. I purchased the Porterbuilt drop member rear with the 4 link. I will not be using the trailing arm crossmember.
Just didn't know if removing it would cause issues. Thank you Again not trying to cause problems just didn't think the reply was appropriate. Posted via Mobile Device |
01-24-2013, 07:32 PM | #11 | |
Junior Member
Slam'ed's reply made me laugh. Posted via Mobile Device Posted via Mobile Device
01-24-2013, 05:19 PM | #12 |
Thank you. That's all I was looking for.
01-24-2013, 05:24 PM | #13 |
Florida Edition
Good looking project by the way and welcome aboard. Lots of very, very smart folks in here.
01-24-2013, 05:41 PM | #14 |
Thank you. That is exactly the reason I joined this forum. This is my first C10 project and I really want it to turn out nice. I have completed several 67 Camaro's but this type of build is way different.
01-24-2013, 07:53 PM | #15 |
This is their two piece drive shaft crossmember. It doesn't have any attaching points for trailing arm so I would assume its for a four-link and you wouldn't need the crossmember unless you had the two piece driveshaft. Seem kinda flimsy without it but then again leaf sprung trucks don't have anything there.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
01-24-2013, 09:31 PM | #16 |
I apologize for my previous comments concerning this post. I took what was said out of context.
Like everyone else here I am wanting to gain knowledge on c10 builds. Posted via Mobile Device |
