"The dude abides"
Radiator Question
Well I have had my truck for a while now and I am finally asking this question. (I am really bored at work and it never really bothered me enough to ask before)
The radiator in my truck is bigger then the stock radiator. I can say this with some confidence because you can see that the piece that holds the top of the radiator in place is not mounted where the stock holes are at. The reasoning behind the bigger radiator is because there are 2 coolers, one on each side. The one side is my transmission cooler and the other side there is nothing hooked up. But the fittings are there and there is even a sending unit sticking in there like for a guage or something. My question is, does anyone know what this was for? Was this a engine oil cooler? The truck originally had the 6.2L Diesel in it and it was the camper special as well. This appears to of come from the factory like this so I am just curious what it is.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
ROCKET POWER!
Yes, if it was originally a 6.2 then it had an engine oil cooler stock from the factory. A good thing to have, except the design of the hoses going to the diesel engine block is so stupid i can't even imagine what the reasoning was behind it.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
"The dude abides"
That is what I suspected. Whenever I get around to putting my BB in there, I will be sure to get this baby cleaned up and piped up to the engine.
Is that a sending unit for a gauge then? There is a unit that sticks out about in the middle of the cooler. In between the upper and lower lines. It's not hooked to anything since the moron that did the swap from diesel to gas. Thanks!
