Old 01-25-2013, 03:39 PM   #1
biohazardbill
Tow Truck
What chassis would have been used for a tow truck. I found a working Ferd Towtruck and am not a big Ferd fan so thought about parting it out and keeping the bed etc to transfer to a chevy chassis. I know it would have been a 3/4 or 1 ton but the wheel base seems awfully short.
biohazardbill is offline   Reply With Quote
Old 01-25-2013, 03:52 PM   #2
awbrown
Re: Tow Truck
I had a 1977 3/4 ton chevy with a plow and had a slide in wrecker setup on that ,used it like a one ton , it was an awsome truck ... if you have snow ,then go with a 4 wd...
awbrown is offline   Reply With Quote
Old 01-25-2013, 04:00 PM   #3
biohazardbill
Re: Tow Truck
I used to live not to far from you (Oakland County) and moved South 3 years ago... moved to where snow is a rare occurance
Was the 3/4 ton a standard lenght truck? I havent measured the wheelbase but it seems short, probably due to the tow truck bed not extending to much farther than the rear wheels.
Old 01-25-2013, 06:12 PM   #4
63burban
Chevy addict
Re: Tow Truck
C30 one ton dually, short wheel base
I can check wheel base and GVW if you need it
63burban is offline   Reply With Quote
Old 01-25-2013, 06:16 PM   #5
monolith
Zero Albedo
monolith's Avatar
Re: Tow Truck
I'm no expert but I got a Holmes 440 wrecker bed to fit onto my 66 LWB 3/4 ton by bobbing about 8" off of the back of the frame.
I recently picked up an actual 1 ton Dually to put the bed on, I wanted to be able to actually use the truck to tow with and I feel a 3/4 ton chassis and suspension might be a little light for the job. Just my opinion though, there are some guys on here that own wreckers who will hopefully chime in.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 01-25-2013, 07:21 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Tow Truck
I think using ferd parts may make a good CHEVY run bad... Just sayin!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-25-2013, 08:16 PM   #7
63burban
Chevy addict
Re: Tow Truck
My truck has a Holmes 400 on it, and yes it can have it's hands full.
Old 01-25-2013, 09:55 PM   #8
2manyprojects
2manyprojects's Avatar
Re: Tow Truck
Mine is a 133" wheelbase Holmes 440.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 01-25-2013, 10:50 PM   #9
biohazardbill
Re: Tow Truck
I know its a holmes, how do you tell what model, I will have to look.
What is the difference in models?
On a side note its Holmes parts not Ferd so I doubt it would hurt the Chevy ... BUT looking at the door hinges they are pocket style and look like the would be a good candidate for a suicide hinge conversion on one of our trucks.
I did get it fired up today... $11 for a cap and rotor and vroom vroom.... winch and boom work.
Old 01-26-2013, 12:52 AM   #10
63burban
Chevy addict
Re: Tow Truck
2manyprojects, what size wheels are on your truck? Is it a C30 ?
biohazardbill, My unit has the number on an aluminum plate, I Googled Holes 400 and found the info I was looking for.
Old 01-26-2013, 09:24 AM   #11
2manyprojects
Re: Tow Truck
It's a 66 C30 the wheels are 19.5
Old 01-26-2013, 12:19 PM   #12
63burban
Chevy addict
Re: Tow Truck
I thought the wheels looked big, how do they work ?
Old 01-26-2013, 08:49 PM   #13
2manyprojects
Re: Tow Truck
Originally Posted by biohazardbill View Post
Its a 440... Big tag under the light says Holmes 440 lol
Yeah they are easy to identify if that tag is there. The 440 is pretty common you should be able to put it on just about any truck.
They work fine. with tires they are the same height as the stock 18's
Old 01-26-2013, 02:13 AM   #14
monolith
Zero Albedo
monolith's Avatar
Re: Tow Truck
I'd love pics of the PTO and winch drivetrain setup before you take it apart-looking on info on how to reconstruct mine and what parts I'm still missing.
Baz
68 Dodge Charger
Old 01-26-2013, 07:55 AM   #15
biohazardbill
Re: Tow Truck
I am not taking it apart for a while, I got it for what I consider a steal so I jumped on it when I could.
I will get some pics this weekend as we need to wash it and get the rest of the branches/vines off of it
Old 01-26-2013, 07:59 AM   #16
biohazardbill
Re: Tow Truck
I know its a Ferd but this shows the bed. I remember seeing a Tag on it but it has been painted over. I will see if I can unpaint it lol
Old 01-26-2013, 09:37 AM   #17
biohazardbill
Re: Tow Truck
Old 01-26-2013, 09:55 PM   #18
awbrown
Re: Tow Truck
Bio , the one I had in my 3/4 ton was one that someone made ,I found it in a junk yard I worked at and made it work for my truck .. I used 3x3 angle laid one over the back of the bed where the tail gate met the bed and the other one was laid upright at the front ..I angled 2 more 3x3 angles down the bed so i could use the same bolts as what held the bed on ,it was much lighter than the holmes unit ..... I have seen people use the holmes unit sans the bed ... but it was rare that I backed out of a tow job , even if the frame flexed somewhat... I had a 65 one ton with a ramp body that we used for hauling junk cars ,used to stack them 2 or 3 high depending on how big they were... that would have made a nice wrecker...
Old 01-26-2013, 09:57 PM   #19
biohazardbill
Re: Tow Truck
Ramp truck. I'd like one of those myself lol
Old 01-26-2013, 09:57 PM   #20
awbrown
Re: Tow Truck
I also used an electric wich so I didnt have to mess with a pto...
