Old 01-25-2013, 04:52 PM   #1
AusTx68
AusTx68's Avatar
New Steering Box- Now I Have Noise and Air
Swapped out my leaking PS box for a new rebuilt unit. The fluid is topped off but I have tons of noise when I steer or brake. After the install I took it for a test drive. When I got back the PS reservoir looked like a soda fountain. It was literally pushing foamy fluid past the cap.
Is all this air coming from my hydroboost? What's the best way to fix the problem??
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-25-2013, 05:01 PM   #2
AusTx68
AusTx68's Avatar
Re: New Steering Box- Now I Have Noise and Air
This was the first time someone other than myself has worked on my truck. As I think thru this, I'm wondering if the guy installed the lines on the steering box correctly. I have -6AN adapters in the steering box so either line will fit. He may have put them on backwards. Damn..I'll need to check. Considering the pressure built up in the reservoir, I'll bet that's the problem.
Old 01-25-2013, 07:44 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You also need to bleed a PS system when it's been worked on.Try jacking up the front wheels and turning the wheel lock to lock.Keep the cap on while doing it but check the fluid level.I shut it off to check but ran the engine to get the pump to flow fluid thru the system while turning the wheel.It may take several cycles left to tright and back.When you have all the air out you shouldn't see many if any bubbles on the top of the fluid.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
