been looking at some pic's of members trucks and everybody seemsto have a fuel filter on the fuel line.my truck does't.should i put one on?I also had a helluva time just getting spark plugs out because of the headers.Having fun with my new truck tho.People know everything here.Don't have money so try to keep maintenance up and truck clean.
SKINNY TIRES RULE!
I have an in-line fuel filter. It was on the truck when I bought it but I would have installed one any way. There is a lot of rain up her in the Pacific Northwest and it can wash a lot of dirt into the tanks at the stations. It's a pretty cheap safety precaution. There was a post several months back about in-line fuel filters and how the glass kind can break and start an engine fire! I have the glass kind but before I get my truck running again, I'm going to switch it out.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Gasser
By all means get an inline filter. Buy one for the size line you have... 5/16 or 3/8, cut the steel line between the pump and carb. Stay away from the glass ones.
Stepside ------------------ 70 sstep tubbed, Muncie 68 swb LT-1
:thud 70 sstep tubbed, Muncie, double hump, snowflake, |
![]() Join Date: Sep 2001
Well its either that or some day you try your hand at finding a replacement for the one inside the fuel port on the carb! Since I have an old 2G that would be fun...
...in-line filters are damn cheap, and they really don't cause any fuel delivery problems unless you get some huge-a$$ thing that the fuel pump can't shove fuel through! ------------------ '69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed! '69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast). Seattle, WA. *See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
![]() Join Date: Feb 2000
I still run the little filters in the carb. There only cost about a dollar and are easy enough to replace. Those gas lines are too spendy to replace for me. just my $.02
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
its all about the +6 inches
I run 2 filters, one under the cab just off the tank, and the glass one on top of the motor.
While it is true that the glass ones can bust or leak, I still run one. If placed using some common sence, they won't hit anything. When my Longhorn got smashed, the filter was fine. ![]() ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
