01-28-2013, 11:27 AM | #1 |
67 gmc
I am having a hard time finding this type of fabric for my 67 gmc, all i can find are the vinyls. I called a few upholstery shops and they have no clue. Also from 67-72 was there a heavy duty 3/4 ton and a light duty 3/4 ton? I know there was in the 73-87. I was looking at a 72 1 ton and every thing looked the same as mine even the suspension.
1967 gmc 4x4 factory air factory buckets 1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne |
01-28-2013, 06:17 PM | #2 |
Re: 67 gmc
I work for an upholstered furniture manufacturer here in MS, and that looks like a lot of the fabrics they are using on home furniture these days. You maybe able to get a small swatch from your seat and take to a furniture repair shop in your area and they can match it up with something close.
01-31-2013, 03:11 PM | #3 |
Re: 67 gmc
Does anybody have any info on the suspension and rear end options from then?
01-31-2013, 08:10 PM | #4 |
Re: 67 gmc
I don't believe you can get an off the shelf lift kit for a pre-69 GM. The springs are wider. I've heard of guys using the later leafs with spacers,but I'd either go to a spring shop or a custom off road spring company,like Deaver. They can make ones that ride better,no just higher.
www.deaverspring.com
01-31-2013, 08:23 PM | #5 |
Re: 67 gmc
Are you taking a sample of the upholstery in? I assume you know it's custom right, that is not factory upholstery.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-31-2013, 09:12 PM | #6 |
Re: 67 gmc
I figured that was factory because it matches the door panels and even the gas tank cover. What would have been in this truck from the factory in a super custom?
01-31-2013, 10:32 PM | #7 |
Re: 67 gmc
It is definitely not factory, neither is the covering on the door panels or gas tank cover. Vinyl would be factory. I will find some pictures of factory interiors for you.
Edit: I took this from another thread, it gives you a good idea of the material and design. There are more photos here: http://67-72chevytrucks.com/vboard/s...d.php?t=515454
01-31-2013, 10:59 PM | #8 |
Re: 67 gmc
Ok that gives me a good idea, I'm am trying to get the truck as close to factory as possible. That end the search for that upholstery, for the springs I was trying to figure out if there was a camper special in 67, I would like to leave it at stock height and get original wheels eventually, I appreciate everybody's help.
01-31-2013, 11:22 PM | #9 |
Re: 67 gmc
There is a board member here that is a great source for factory seats: http://67-72chevytrucks.com/vboard/s...d.php?t=532345
Tags |
gmc 3/4 ton chevy 3500 |
