01-28-2013, 04:33 PM | #1 |
Old member
Transmission bolts loose
As the title states all my bolts were loose and I have tightened them up several times before. What is the trick to keeping them from backing out?
I put star washer's on them this time with RTV. I hope this will do it. Want to know what all u have used. I even thought about putting longer bolts in it and nuts on them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-28-2013, 04:51 PM | #2 |
Re: Transmission bolts loose
I have just used new split lock washers every time and they've never come loose....I think I have torqued to 35 ft/lbs.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-28-2013, 05:04 PM | #3 |
Old member
That's what I started to use but found the star washers and figured they be a little better. I just hope they hold tight!
