Old 01-30-2013, 04:51 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
99 silverado tear down question
I have started tearing down my wrecked 99 to put the engine and tranny in my 70, my question is... I know that i will obviously be taking all of the stuff from under the hood as far as sensors, and eliminate the unneeded sensors like the evap stuff, but my question is do i need anything else besides the brake light switch and its pigtail?
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 01-30-2013, 10:05 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 99 silverado tear down question
That's a matter of personal preferance, depending on how much you want to use off the donor truck, but mainly you just need the engine/trans and harness. Everything else usually won't fit the best, like the radiator ect. I took all the A/C stuff out of an '03 and put it in the A/C box of my old blue '72 and it worked great, but was alot of work.
Also, I would use an older brake light switch out of an '80's GM car or truck with cruise since it's a direct fit, you won't have to make any brackets or anything like you will probably have to do to use the '99 switch.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-31-2013, 09:24 AM   #3
1970 C10 MJW
i did plan on removing all the AC stuff, but my 70 isnt a AC cab... and glad to know about that brake light switch, what car or truck would you recommend? idk if you remember but I was talking to you a while back about getting a cruise control switch from you, so whatever I use needs to be able to support a torque converter lockup and cruise..
Old 01-31-2013, 09:29 AM   #4
ls1nova71
ls1nova71's Avatar
There's alot of cars and trucks that use that brake switch, but if you're going to the parts store just ask for one for a 73-87 Chevy truck with cruise control.
Old 01-31-2013, 03:03 PM   #5
1970 C10 MJW
lol I work at a parts store I just didn't know which one i should get lol, I work for a local AC Delco distributor
