01-31-2013, 08:42 AM | #1 |
lowering longbed
How should I lower my 77 longbed WITHOUT having to swap out the driveshaft to a one piece? I dont want to dump the truck. In fact, Id be happy with a 2" drop all around. although 2 up front and 3 in the rear would be even better
01-31-2013, 11:16 AM | #2 |
Re: lowering longbed
Flip kit and spindles and coils
01-31-2013, 12:31 PM | #3 |
That would result in a 5/6 drop wouldnt it?
I guess my question is more how to do a 2/3 and if that would still require going to a one piece driveshaft as I have read. Is going to hangars and only using the first 1" drop hole going to be beyond not having to swap the driveshaft? I'm already assuming spindles for the front but not sure if there is much difference between bell tech, DJM, CPP etc.......by the way its also the heavy half ton with larger brakes and more leafs Last edited by gramps77; 01-31-2013 at 12:39 PM. |
01-31-2013, 01:08 PM | #4 |
Lowering springs front, or spindles.
Shackle in the rear for 2". For 3" I think you need to flip the rear, and use a lift shackle. |
01-31-2013, 01:14 PM | #5 |
On a 3" drop I don't think you'd need to do much to your DS.
I have a C20 long bed, and even if I dropped my rear down 8" All I would have to do is drill new holes to move my carrier bearing back 1 inch. I have plenty of room on my youke for that for some reason. |
02-01-2013, 08:45 AM | #6 |
Theres no need to swap your driveshaft no matter how much you lower it. Flip kit will lower it 6"+. Mine came down 8" in the back with a flip kit and 4 degree shims, but I also went from 3/4 ton leafs to 1/2 ton leafs. Mine is borderline needing the carrier bearing raised up. When i notch the frame and bag it, I will have to do the carrier as well.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
02-01-2013, 10:10 AM | #7 | |
I'd cut the coils in the front and relocated the spring hangers on the rear. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-01-2013, 05:52 PM | #8 | |
02-01-2013, 07:16 PM | #9 |
im dropped like 8+ in the rear with a 2 peice. you just have to modify the carrier bearing hanger. i would just chop a coil in the front. drop shackle in the back and remove 1 or 2 of the shorter leafs
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
02-03-2013, 05:15 AM | #10 |
It's just a bad idea...Don't do it...
02-03-2013, 09:25 AM | #11 |
What's a bad idea? Lowering?
I lowered my dually 5/7 and stayed with the two piece shaft, no problems.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
02-03-2013, 10:00 AM | #12 |
I put the drop shackles on the rear of my LWB and one day WHEN I HAVE THE TIME, I'm going to cut a coil from the front. Might just buy the lowering springs though
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
