Return Spring/Kickdown Cable Setup
Anybody have a picture of how their return spring is setup on either a Edelbrock or Carter carb? I just changed out my Holley for a Carter and can't seem to get the return spring to work right when my kickdown cable is hooked up. I took the kickdown cable off because I need a new one so now I have the return spring sitting on that linkage on the carb.
Thanks!
Scott Shelbourne Last edited by BigRed; 06-12-2003 at 12:01 PM. |
Ok, I don't necessarily need pics, but how about a description.
Scott Shelbourne |
Alleged Member
They sell hookups for the carter/edelbrock. In a pinch I hooked one up to the top of the linkage and pulled it forward to anything there it could be fastened to. I tried the thermostat hose clamp and it worked good.
:gwc: :gwc: :gwc: :gwc: :gwc: :gwc: |
BAD BOW-Silverado XST
Does this help? The adaptor should be in the carb box.
![]() PS- I have discovered that the square bores carbs need this adaptor. This will keep the kickdown or TV cable fully extended at WOT. |
Actually, this is a slightly old thread. I did rig the return cable up and have it routed forward instead of backwards like it was before. Thanks!
Scott Shelbourne |
