Old 01-31-2013, 05:37 PM   #1
Oilbrnr
Oilbrnr's Avatar
LY9 Front Assessories
So I've had this 4.8 sitting in my garage now for going on five years. The 350 in the K5 has hit the wall and is consuming gasoline and 10-30 in equal rates, so the time has come.
I need some pointers though.
First off, you can see from the picture that I'm missing the alt., PS pump and accesory bracket. Also I'm missing the pedal and TAC (think that is correct).
Out of ignorance, what should I start searching for regarding the accessory pieces? I believe this to be out of a 2007, so how many years plus or minus can I be looking for to find these parts?
Second, I think I'd like to go with a whole new wiring harness. What are my options as far as vendors go that you've had good success with, that could possibly also provide the go pedal and TAC?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 01-31-2013, 06:09 PM   #2
Oilbrnr
Oilbrnr's Avatar
Re: LY9 Front Assessories
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 01-31-2013, 09:12 PM   #3
72Blazing
72Blazing's Avatar
Looks like you just need the alt. power steering pump bracket. I have several 04 chevy trucks I am parting out. I can get you what you need. Also have the drive by wire pedal and module you need. Let me know.
72Blazing is offline   Reply With Quote
Old 01-31-2013, 09:18 PM   #4
Jon01
Jon01's Avatar
If you can get a harness for free or very cheap then it makes sense to chop it up yourself or send it out - tech guys recommend Bill @ BP Automotive.
If not buy a PSI harness.
With 243 heads I believe it would be an 07+ motor. Should be a strong runner!
Jon01 is offline   Reply With Quote
Old 01-31-2013, 10:03 PM   #5
Oilbrnr
Oilbrnr's Avatar
Thanks guys!
72Blazing I'll PM 'ya about the parts.
I know it is not a 6.0+, nor is it the probably wiser 5.3 but, I have it. And it is paid for. :-) I'm figuring it will be a tad better in stock trim then the original 350 is/was. It is my DD on a 40 mile round trip to work. 6 of those are on dirt to our house which is heavily washboard generally 90% of the time. I use it to help save wear and tear on my DMax!
Think I should keep the stock cam?
I wish blowers were cheaper.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 01-31-2013, 10:52 PM   #6
ls1nova71
ls1nova71's Avatar
2007 was an odd year, they made both body styles of trucks. That manifold cover makes me think that this is out of the new body style of truck and would be a GenIV. If that's the case, you don't need a TAC, all you'll need is a pedal. Also looks like it has a harness on it? Why not use it? Also do you have the PCM?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-01-2013, 11:25 PM   #7
Oilbrnr
Oilbrnr's Avatar
I do have the PCM and the harness Eric, I'm just not sure I want to pick the harness apart myself. Not so much that I don't like doing wiring work, but it would be nice just to have a plug and play situation ready to go.
I just hope when all is said and done, I'm not too disappointed with the power of the peanut 4.8. I just keep telling myself that it will have more power than the stock 350, err at least on paper!
Looks like I've got the missing LS parts sourced from 72Blazing with the exception of the go pedal. Now I need to get the clutch/flywheel and new hydraulic master and slave cylinders, fuel tank, pump, filter, lines, CableX (hope it holds up), and probably 100 other items that I'm not listing!
But if I don't start somewhere, this project is never going to get done! This motor has been sitting in my garage going on 5 years now. I just hope I can get this finished before summer hits. Not fun working out there when it is over 100*. A swap cooler only goes so far.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 02-01-2013, 05:09 AM   #8
c10seconds
c10seconds's Avatar
I would think its a 5.3 being that you have 243 casting heads. What does the valley cover look like?
c10seconds is offline   Reply With Quote
Old 02-01-2013, 10:14 AM   #9
Oilbrnr
Oilbrnr's Avatar
I'll take a few more pics of it tonight and post them up. On the black of the block though there is a blue dot painted on the 4.8 casting. I figured that indicated the size. What is the definitive way for me to find out exactly what I have?
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 02-01-2013, 12:12 PM   #10
ls1nova71
ls1nova71's Avatar
243 heads are real common on 4.8's so I would believe that's what it is. To verify, you can pull a plug and look at the top of the pistons, if they're flat it's a 4.8, if they're dished it's a 5.3. that said, it's almost impossible to see the difference through that small hole. You could always pull the oil pan and check the numbers on the crank.
Old 02-01-2013, 02:37 PM   #11
mavdog32
I also have an extra accessory bracket, if you need it still just drop me a PM.
mavdog32 is offline   Reply With Quote
