01-31-2013, 06:08 PM | #1 |
Alternator help
I can't seem to find the replacement alternator for my 71c10. Truck has a 454 BB block out of a 89-90 silverado. Here is the kicker, truck has serpentine belt but auto parts can't seem to find a matching alternator for it. Either they find the right alternator with the correct plug but the then the pulley is a v-belt.. The alternator that is on right now is part# 1100264, when I go online it also has a v-belt and not the serpentine pulley. Do y'all think pulley was changed on alternator and that's why I can't find right one? Thanks for the help
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
01-31-2013, 06:15 PM | #2 |
Proprietor of Dale's Corner
Re: Alternator help
Yep, swap the pully
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
01-31-2013, 06:15 PM | #3 | |
Project Heaven in my 67!!!
Re: Alternator help
01-31-2013, 06:31 PM | #4 |
Active Member
Re: Alternator help
Can you compare with one that has the serpentine belt pulley to see if it's the same? Try NAPA or Carquest if you have one in your area. They seem to have more knowledgeable people that can help you out.
If you already bought it and it has the pressed on pulley, you can rent the tool at Autozone or if you think you will do it again in the future, buy the tool kit for $20-$30.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-31-2013, 06:33 PM | #5 |
Re: Alternator help
Ok thanks, I didn't know it was ok to swap pulleys, I'll try that
01-31-2013, 08:03 PM | #6 |
Re: Alternator help
I have that same set up (88-90) on my 76 Monte (383). I don't remember having to change the pulley as I used everything off the donor truck. But a pulley change should do the trick.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
01-31-2013, 08:36 PM | #7 |
Re: Alternator help
Is there any DIY online? Can't seem to find any
01-31-2013, 08:57 PM | #8 | |
Active Member
Re: Alternator help
If you have an impact wrench it works a lot better if you have one otherwise any shop can do it for you.
