Old 01-31-2013, 10:57 PM   #1
70blackfish
Any Pictures of how rear swaybar mounted?
I have trailing arm rear....would love to see pictures of how you mounted your rear sway bar........
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-01-2013, 02:17 PM   #2
67basketcase
Re: Any Pictures of how rear swaybar mounted?
I'd like to see this too.
67basketcase is offline   Reply With Quote
Old 02-01-2013, 02:55 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Any Pictures of how rear swaybar mounted?
Well it depends on which one you buy as to how it mounts. The aftermarket ones mainly mount to the frame and arms.
The camaro ones mount to the frame and rear axle as I did mine.
This is mine it's the camaro bar.
Bought it out of the junkyard.
Painted it:
Spacers I made for the frame:
Kit for Installing it:
Here is the thread on my install.
http://67-72chevytrucks.com/vboard/s...d.php?t=305902
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-01-2013, 05:41 PM   #4
67basketcase
Ah, point it backwards.... Why didn't I think of that?
Old 02-01-2013, 05:43 PM   #5
67basketcase
I think I have a rear bar off of a 90's tahoe sitting around somewhere, wonder if that will fit this way.
Old 02-01-2013, 06:11 PM   #6
Longhorn 70
Longhorn 70's Avatar
but....but....but I have leaf springs.....Will it, can I, I need to...........
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-01-2013, 06:15 PM   #7
jjzepplin
jjzepplin's Avatar
THIS is also my question.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-01-2013, 06:21 PM   #8
blkcorvair
blkcorvair's Avatar
what year camaro?
blkcorvair is offline   Reply With Quote
Old 02-01-2013, 07:00 PM   #9
capev86
what year camaro?
1982+. the biggest bar for these cars was 1" dia. to get the big bar you will have to look at an 80's car. consumers @$#%&'ed about the harsh ride so even selecting the hot suspension option still got a smaller rear bar in the 90's.
i bought the sway bars from CPP, but i don't like the setup for rear bar for the trailing arm setup. i was thinking of adapting the CPP rear bar for a leaf spring truck. as long as it clears the 3/4 ton Corp/Eaton diff and track bar mount, it should give better ground clearance. and unlike with the camaro bar, the ends will line up with the truck frame (no spacers needed). also, the CPP rear bar is 1-1/8" dia which i think is a good idea on a suburban.
capev86 is offline   Reply With Quote
Old 02-01-2013, 07:34 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-01-2013, 08:03 PM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Any Pictures of how rear swaybar mounted?
I can't say 100% if it will work but I see no reason it shouldn't though.
