02-01-2013, 03:39 PM | #1 |
Control arm bushings
I need to rebuild my front control arms. What do you guys think- keep the existing steel bushings or go with the later model '73-87 rubber bushings? Which are better?
02-01-2013, 03:57 PM | #2 |
Re: Control arm bushings
I changed my front end to 76' and then rebuilt everything.
FYI; the control arm bushings are tuff to get out.... I did not have a press, so I torched the rubber then push them out! kind of messy but it worked!
People who make excuses didn't want to do it in the first place! http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
02-02-2013, 12:49 AM | #3 |
60-66 Nut
I prefer the '73-'87 rubber bushings. The steel bushings need to be greased, otherwise they start to squeek.
02-02-2013, 07:56 AM | #4 |
Watch out for your cornhole !
When I built my 63 I ran the costs to rebuild my original arms versus the 73-87 arms. The later arms are much cheaper to do. I used later arms with an Energy Suspension urethane bushing kit from Summit for like 70 dollars versus having to buy the steel bushing kits which were something like 3 times that amount for the original arms.
02-02-2013, 11:31 AM | #5 |
Cool guys. I decided to go with the later arms and bushings. Buy once, cry once.
I wonder if there's any noticeable difference in ride quality between the two bushing types? Probably minimal eh? |
02-02-2013, 02:31 PM | #6 |
I also changed to rubber bushing. Go to Youtube and sreach for "contrl arm bushing replacing" , this guy cut the inner tube with hacksaw and using a long screw and 3inch. pipe, he pushed the bush out. To install, he reverse the pipe and long screw. Bets paying more then $200 at Brake shop.
02-02-2013, 08:24 PM | #7 |
Who Me?
I went with original bushings when I rebuilt my front end. It was just easier that way for me.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-03-2013, 06:27 AM | #8 |
Not trying to hijack the thread but I replaced my bushings with the original style steel ones and now I can't get them to take any grease. I've tried several different approaches. Anybody have similar problems and if so what solution did you come up with?
