Old 02-02-2013, 01:28 AM   #1
c10 custom
dropped axle
hi guys i was wondering how to lower my 1947 gmc advance design truck shortbox whats the lowest you can go with dropped axles and does anyone have pictures of there truck with dropped axles thank you
c10 custom is offline   Reply With Quote
Old 02-02-2013, 02:15 AM   #2
dubie
dubie's Avatar
Re: dropped axle
i wouldn't go any lower than 4" with a dropped axle. I've heard you can use a 6" if you can find it but require more work on everything else
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-02-2013, 10:13 AM   #3
nvrdone
Re: dropped axle
I have a 3" dropped axle from Sid's on my 1949 chevy 3100. That was the lowest I could go & not have the bottom of the axle hit the road if a tire came off the rim. I also had to mount the tie rod under the steering arms so it would clear the springs. Now it looks & handles much better. Good luck
nvrdone is offline   Reply With Quote
Old 02-02-2013, 05:00 PM   #4
NEWFISHER
NEWFISHER's Avatar
Re: dropped axle
Www.droppedaxles.com ask fo sid. Read the how to link on the chevy section, it will walk you through it. A truck can be dropped in a day when you have everything in front of you. I bought everything Sid offered including steering and rear blocks. I also have new shackles and full 8 pack leaf packs. I could pull a couple leafs and go lower, but I haul a lot with it too. Here's mine.
NEWFISHER is offline   Reply With Quote
Old 02-04-2013, 07:05 PM   #5
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
Re: dropped axle
Now this is sweet!
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
