02-02-2013, 07:03 PM | #1 |
Active Member
New Hood to Cowl Seal/Raised Hood
I know there are several threads on this but I just installed a new cowl seal and stainless trash guards. I know some say to try new hinges and springs but I press down on the back of the hood when it's closed with all my weight and it still doesn't go flush. Will new hood hinges and springs really be strong enough to hold it down or make a difference? I tried adjusting the hood hinges but it make's no difference. It doesn't help I got the POS LMC cowl seal.....
So should I just try to get a new seal from a vendor (Classic HeartBeat) or try new hood hinges/springs???
67 C20 283/4 Speed |
02-02-2013, 08:20 PM | #2 |
Re: New Hood to Cowl Seal/Raised Hood
Your hood to cowl seal should be a V shaped seal not L shaped. Rock auto has the correct seal for our trucks.
02-02-2013, 08:26 PM | #3 |
Mine did the same thing, I just took it off. I can't see any real need for it anyway, unless it does something I haven't thought of?
http://smg.photobucket.com/albums/v655/aaronhero/ |
02-02-2013, 08:31 PM | #4 |
Moderator
You can bring the back of the hood down by adjusting the hinges. Open the hood, loosen the hinge bolts that attach to the fenders. Then, push the hood further up to rotate the hinges back. Tighten the bolts, keeping the hinges in that position (it is easier to do this with two people, so you can hold the setting) Close the hood carefully...you will see that this "pulls" the back of the hood down when shut. If you over adjust, the hood will scrape the cowl, or go down too far past the cowl. If you play with this adjustment, you can dial it in.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-02-2013, 08:39 PM | #5 | |
Active Member
02-02-2013, 11:33 PM | #6 | |
Roto Reuter thats the name...
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-02-2013, 09:01 PM | #7 |
I tried to adjust mine as you describe with no luck, I'm thinking my hinges or springs are worn out. Would that be the problem? I don't see and wear but can't really test the springs.
02-02-2013, 09:07 PM | #8 | |
Active Member
02-02-2013, 09:14 PM | #9 |
I noticed the brace the on the hood where the hinges mount flexes a lot while opening and closing the hood, I wonder if the brace has bent over the years? My 72 hood fits flush, that's without the seal, my 69 sticks up in the back without the seal. The hinges in my 69 don't seem to have any play and the springs seem strong when opening the hood. I have the hinges all the way down as well. When I repaint the 69 I'm going to try to mess with the brace and see if I can get the hood to seat.
02-02-2013, 11:04 PM | #10 |
Registered Cruiser
When it's cold out, try relaxing the seal with a heat gun. This works for door seals too.
I intend to live forever. So far, so good. |
02-03-2013, 09:07 AM | #11 |
Adjustment is first option of course. But elongated rivets in the hinge can cause this also n very hard to see. Using the correct seal then the adjustment on the hinge is the first two steps.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
02-04-2013, 03:45 AM | #12 |
Active Member
Anyone know the point for the hood to cowl seal??? Does it matter if it's on or off???
02-04-2013, 06:01 AM | #13 |
It is to help prevent engine compartment fumes from entering the cabin air intake plenum.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-05-2013, 01:20 PM | #14 |
Florida Edition
I think this is a common problem on these trucks. My hinges are adjusted as far as they go and are solid pieces, the seal is NOS so the only cure on my truck is to elongate the holes in the hinges.....someday, but its ok for now.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-04-2013, 05:35 AM | #15 |
i think it is just to minimize the elements from getting through
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
