Old 02-02-2013, 10:05 PM   #1
57rookie
Wiring diagram for stock am/fm cassette for a 1986
I sold my 57 and picked up a 1986 GMC Wrangler that has all the options.
I am starting the restoration to stock. I have the originaI GM digital tuner stereo with am/fm cassette that I want to reinstall but the previous owner cut out the harness end and wired up a din style stereo. I don't have the harness plug that plugs into the back of the original stereo so I don't know which wire goes to which pin in the back of the original factory stereo. Does anyone have a schematic showing which color wire goes to which pin in the back of the factory stereo. Thanks!!!!!
57rookie is offline   Reply With Quote
Old 02-03-2013, 01:55 AM   #2
ray_mcavoy
Re: Wiring diagram for stock am/fm cassette for a 1986
The wiring diagrams hatzie posted here should help --> http://67-72chevytrucks.com/vboard/s...d.php?t=545416
Also, if you look real close at the radio's metal case, most of them have a pinout diagram stamped right into the top and/or bottom cover. Sometimes they're a bit faint and hard to see at first.
I believe you'll need to get a set of connector plugs like these --> http://www.ebay.com/itm/Radio-Stereo...sories&vxp=mtr to splice onto the wires that the PO cut so you can plug them into the GM radio. These connectors were pretty common on a lot of GM vehicles from the late 70's up into the 80's so they shouldn't be too hard to find at a junkyard.
The digital tuner radio you have will most likely have an additional 2-wire plug sticking out the back. The orange wire on that goes to a constant battery source and the brown wire is a dimming signal for the digital display that gets wired into the tail/parking light circuit.
ray_mcavoy is offline   Reply With Quote
Old 02-03-2013, 04:09 PM   #3
57rookie
Thank you Ray! The problem I have is that the stock stereo does have the pin outs on the top of the radio but it does not list the corresponding color of wire, so I know as an example the location for the LH front speaker wire but I don,t know which color of wire it is, i.e green, blue, ??????, so I am staring at a bundle of cut wires with mulitple colors and I don't know which wire goes to which pin out?????????????????????
Old 02-04-2013, 12:10 AM   #4
hatzie
Moderator
hatzie's Avatar
As Ray said. A PDF of the Factory 1986 CK 10-30 GM wiring diagrams is in the thread he linked... The same thread is in my sig.
These aren't the partial diagrams you find in Haynes, Chilton, Motor, ... Every wiring color, wire gauge, circuit number, and GM connector number for every option available that year is in those diagrams.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-04-2013, 10:10 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
may help
watch the 4 and 14
14 can go to the marker/running lights
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
