02-02-2013, 10:46 PM | #1 |
Shock extensions/lowered truck
From what I understand when you lower a square you have to buy shock extenders for front and back both , correct?
The flip kit I'm looking at has shock extenders for the back, but where can I get some for the front? And, can you also use shorter shocks instead of shock extenders on the front? I'm planning on lowering mine about 4/5. Thanks guys. |
02-02-2013, 11:32 PM | #2 |
Re: Shock extensions/lowered truck
Shock extenders are for the rear, as the shock angle gets to flat for them to work effectively.
The front just gets shorter shocks if you use drop springs. You could mod front shock mounts if you feel you need longer shocks, but I couldn't imagine why. For the rear you could move your shock mounts forward, and run shorter shocks. Which would be better for handling if your going to push your truck towards the edge on a road course. |
02-02-2013, 11:44 PM | #3 | |
I will most likely be using drop spindles and springs on the front, so can I just leave the stock shocks as is on the front? |
02-03-2013, 12:24 AM | #4 |
You can often get away with it for awhile if you don't bottom out to much. Just measure the shaft after you drop it, and if you have 2 inches left you'll be fine for awhile.
KYB's are cheap, and are about as good as any shock out there for 3 times the price. |
02-03-2013, 12:44 AM | #5 | |
02-03-2013, 12:44 AM | #6 |
The best way to answer the question correctly is to measure your specific application for the amount of travel you have w/your current combo of parts. The fronts are easy to just relocate the upper mount higher on the frame-rail & use a stock p/n replacement shock.
Check out Performanceonline they carry them. http://www.performanceonline.com/196...Mount-Kit/?pa= See if these might work for you |
02-03-2013, 01:01 AM | #7 | |
02-03-2013, 06:57 PM | #8 |
The big difference is less travel w/shorter shocks. OE shock length is about perfect by simply relocating the upper mounting point.
02-03-2013, 08:18 PM | #9 | |
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
02-03-2013, 09:52 PM | #10 |
yes
02-03-2013, 10:08 PM | #11 |
If I want to run shorter shocks, I've still not been able to find out what length I would need.
02-03-2013, 10:08 PM | #12 |
Diggin The SquareLife
i have drop shocks all the way around an i have 5/6 drop.....im having to buy shock extenders for the rear as my shocks not short nuff an have cracked my frame from bottoming out
02-03-2013, 10:13 PM | #13 |
I'm planning on getting this for the rear, it says it comes with shock extenders.
http://www.summitracing.com/parts/dj...mc/model/c1500 Can anyone tell me if they see shock extenders in the picture in that link? I don't know what they look like. |
02-03-2013, 11:01 PM | #14 | |
Do yourself a favor and dont go with A DJM flipkit
02-03-2013, 11:03 PM | #15 |
02-03-2013, 11:18 PM | #16 |
Djm makes a poor quality flip kit. Use Belltech, mcgaughys, or western chassis. Im not sure if they offer kits with sock extenders.
02-03-2013, 11:19 PM | #17 |
02-04-2013, 12:28 AM | #18 |
I noticed some flip kits say 5 inch drop and some say 6 inch drop. Is there really a difference? I'm just wanting to do 5.
02-04-2013, 12:58 AM | #19 |
It depends on the leaf spring thickness as in how many leafs you have, if you have a standard 3/1 leaf it will drop it 5in, if you have the 7/1 it will drop it 6in. Also dont worry about drop shocks with the drop you are doing, its just a waste of money IMO. Stock shocks will work fine with the drop you want to do. The minimum components you will need to drop it right are a set of drop spindles, a set of flip brackets, and shock extenders.
John 82 Chevy Silverado 350ci/TH350 |
02-04-2013, 01:06 AM | #20 | |
What confused me was this http://www.summitracing.com/parts/ws...1500/year/1982 In the description it says Additional features include: * Axle locator, U-bolts, 6-hole plates, and fasteners * Allow axle to be relocated for a 6 in. drop But, that will be good if it just does a 5 inch drop on mine. Any shock extenders for the rear, you can recommend? |
02-04-2013, 01:28 AM | #21 |
Yep you have the basic 3/1 leafs. Yea I can understand the confusion, the measurements stated in these kits are really appoximate not 100% dead on.
I would recommend these. http://www.summitracing.com/parts/ws...olet/model/c10 http://www.summitracing.com/parts/wst-2104
02-04-2013, 01:31 AM | #22 | |
02-04-2013, 02:24 AM | #23 |
im gona order the same shock extenders tomorrow..i like western chassis...I used there spindles and springs up front
02-04-2013, 03:26 AM | #24 |
you wont need drop shocks on the, with the rubber bump stop removed you can bottem out and still have plenty on compression in the shock. teh rears will get you to about the bump stop mount, van shocks will get you to the frame
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
02-04-2013, 01:20 PM | #25 |
Measure the parts you actually have & confirm if it will/wont work. In this case, measure the amount of compression travel before the shock bottoms out & compare it to the length of the shock @ ride height.
Many comments made on the internet are exceptions rather than common results.
