02-03-2013, 07:13 PM | #1 |
Need Help With Tires
I have a 1987 chevy LWB with 255/55/18 on front and currently have 265/60/18 on back. I would like to have a much wider tire in back without going taller. What tire do you guys recommend? Thanks
87 Chevy R10 LB 02 Nissan Sentra GXE |
02-03-2013, 07:29 PM | #2 |
Re: Need Help With Tires
Use this site... you can punch in different tire ratios and sizes and see how they compare to what you have on there currently
http://www.tacomaworld.com/forum/tirecalc.php |
02-03-2013, 08:12 PM | #3 |
02-05-2013, 12:39 AM | #4 |
nice truck texasbigbear_wink! how much did you lower it?
02-05-2013, 01:32 AM | #5 |
Thanks, Not sure of exact number of inches but I just did a axle flip on the back with 3" drop spindles on front and cut one coil off. I will try and get a stock pic of it up so you can c how much it dropped.
02-05-2013, 01:48 AM | #6 |
Before.
02-06-2013, 11:22 AM | #7 |
Looks good man!
02-06-2013, 12:39 PM | #8 |
G8DAN Thanks.
02-06-2013, 12:49 PM | #9 |
The width you can go also depends on what rim width you have, if you have for example 15x10, I've heard of people putting a 295 on the back.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
02-06-2013, 01:08 PM | #10 |
They are 18x8 front and 18x9 on back. I was looking for someone that new tires really well to say Ok your running a 265/60/18 and you want to go wider but not to much taller you can run ? The problem I have using the tire calculator is that I find a size I like but that size will not be available.
02-06-2013, 01:38 PM | #11 |
Yeah I understand what you mean, in my honest opinion the widest you can probably squeeze on your truck is about a 285 with the rim you have on the rear right now.
