M22W from four gear trans?
Is anybody running a trans build by four gear trans? Im looking at buying one of their M22W street/race version for my 71' turbo LSX. It Will be in the 600rwhp range. Just want to see if i can get any feedback on them before pulling the trigger? I think he makes his own gears instead of using the Italian gears? Is this correct?
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
Fabricate till you "puke"
Re: M22W from four gear trans?
I cant give much "feedback" on the trans you are looking at, but will say that the biggest trouble with a Muncie trans are the ratios! Your close ratio trans is a 2.20 1st, while that does work with a 4.56 gear on the track, I would opt for a TKO 600 trans, go 3.42- 3.73 on the rear gear & take advantage of that lower 1st gear.....as well as the overdrive gear
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#3 | |
My Carbon Footprint
I need to do some checking while mine is out and see just what my 1st gear ratio is. The first time I drove it I thought "man...these 3.73's aren't bad at all". Then I shifted 3 more times in about 50 feet and realize that she sure is a close ratio trans with a tall 1st.
Tags |
4spd, gear, m22w, trans |
