URGENT(ish)
Hey, so i was showing my friend how the gears change in my truck, and my transmission is now locked up. The shifter is in neutral, but the transmission is in first. I know because I can start it and drive a little and it for sure is in first, but my column shifter wont do anything. Any ideas.
1971 chevy c10 lwb. 350 v8 3 on the tree manual transmission any help!! =) |
Re: URGENT(ish)
On my 67 i had to down shift it from 3rd to 2nd and then to 1st if i didnt it would get stuck.
My fix was to open the hood and move the rods up and down untill it freed up. It was quick and easy but i never could figure out exactly what movment worked. I hope this helps you. Last edited by white 67; 02-08-2013 at 11:38 PM. |
Who Changed This?
![]() Join Date: Jan 2013
Re: URGENT(ish)
Yup. Your shifter is toast, due to being sloppy. It's going to take some work to get it better, but start with replacing all the bushings in the shift linkage, that'll take care of most of it. The rest of it is in the trans.
Re: URGENT(ish)
Should be able to get it unlocked with some prying of the linkage I had a old 3sp that did that if you did not shift it slow.
Posted via Mobile Device |
Re: URGENT(ish)
Pop the hood and get the two ears that come out of the column ( the ears that the linkage rods attach to) lined up again.When the gear shift is in neutral they should be lined up together not one up and one down). It will then shift again. When the column is worn, the ears don't work as they should i.e. you are trying to move into two gears at once - and you get a jam. This usually occurs when you are shifting from first to second. One trick to shifting with a worn column, is to go straight up to neutral, straight down towards the dash in neutral and then straight up to 2nd. If you try to shift it quickly and at a diagonal, it will jam often.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Too many projects
Re: URGENT(ish)
Mine used to do that. Chock the tires and apply parking brake then crawl underneath and push the shift arms on the tranny to verticle (neutral).
Shift slower and try not to cut the corners of the pattern. Mine used to get stuck in 1st and 2nd at the same time, way too much fun to fix at the stoplight.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
1969 Custom 30 wrecker
Re: URGENT(ish)
I had a '77 that liked to do that at busy intersections!
![]() My "fix" was to shut if off, pop the hood and push the fingers or whatever they were back into the steering shaft. By then most of the cars that were behind me now pissed off had went around me. These parts were always sticking out when this happened. I never investigated it further as it would have cut into my drinking time too much back then. ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Re: URGENT(ish)
When it happens get under the hood and take the shift arms at the column and line them up with each other. You'll be in neutral. Takes seconds. My old Advanced Design made me a PRO at it. I found that w/ my rig trying to 'slip' from one gear to another or speed shift made it happen every time.
I am a Referee of life.
Re: URGENT(ish)
Clean the shift mechanism under the hood.Then lube with some spray white lithium grease.Then do this
http://67-72chevytrucks.com/vboard/s...d.php?t=215307 Try it,you'll like it. There have been thousands of perfectly good column shifters replaced with floor shift because no one knew to just adjust them.I know I have been guilty of replacing them because I didn't know.I like the column shift,it's different and few people have ever driven one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
