Old 02-10-2013, 12:42 AM   #1
61memo
Brake lines
Hello everyone this might sound like a dumb question on my proportioning valve theres two inserts I know one is for the drum brakes and the other is for disk brakes what goes where im ready to do my hard lines thanks
61memo is offline   Reply With Quote
Old 02-10-2013, 12:55 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Brake lines
I did a forum search and found a couple threads
http://67-72chevytrucks.com/vboard/s...ighlight=valve
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-10-2013, 02:08 PM   #3
61memo
Re: Brake lines
Thank you for posting those threads they were helpful I was looking at my propotioning valve and it only has two inserts, on the picture on one of those threads the propotioning valve has three so im guesing they are factory im doing an after market disk brake conversion once again thank you for your help
Old 02-10-2013, 02:46 PM   #4
LostMy65
LostMy65's Avatar
Re: Brake lines
What make valve do you have?
Is it adjustable?
Typically, on an aftermarket kit, you only need to put a valve inline for the rear drums.
It's used to reduce the pressure to the rears so they don't grab first and cause a backend skid.
Old 02-10-2013, 06:16 PM   #5
61memo
Re: Brake lines
My disk brake conversion kit is from CPP there is no brand on the propotionung valve the valve only has two inserts one is bigger than the other by what I researched the smaller insert is for the disk brakes (3/16)and the bigger insert (7/16) is for the rear thank for your info.T he valve is not adjustable
