Old 02-12-2013, 02:41 PM   #1
Mister-B
Speaker options for original AM radio?
I installed an original AM radio. I just got a replacement antenna, so I wired everything up. The radio is getting power, because the light to the display comes on when I turn the radio on. Unfortunately, there's no sound. I would suspect the original speaker is shot.
The problem now, is that I checked Brothers and LMC, but the speakers they sell for that spot are stereo. Can I even wire those up to this radio? If so, how?
Any other options? I want to keep this radio and stock type setup. I don't want a different unit, additional unit, speakers mounted in a non original spot, etc.
Mister-B is offline   Reply With Quote
Old 02-12-2013, 02:49 PM   #2
TROOPER 247
TROOPER 247's Avatar
Re: Speaker options for original AM radio?
Mr-B. I had the same problem. I sent my factory speaker off to get re-coned. After install, and 80 bucks later, it still didn't sound all that great. I ended up buying one from turnswitch.com. I think the quality and sound is great. You will need the 10 ohm mono speaker in the 4x10. If you give them a call, they can fix you up for about 50 bucks. Lmc and others just sell the 4 ohm which can possibly burn up our factory radios.
TROOPER 247 is offline   Reply With Quote
Old 02-12-2013, 03:20 PM   #3
Mister-B
Thanks so much. That's great info. Were you able to just mount it up with the original mounting hardware in the original spot?
Old 02-12-2013, 03:42 PM   #4
1972SUPERSB
1972SUPERSB's Avatar
I bought the one from turnswitch as well. Sounds great and bolts right up to stock brackets. You can't go wrong with their speaker. Here is a pic of the speaker I bought from them
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 02-12-2013, 03:43 PM   #5
1972SUPERSB
Another pic
Jeff
Old 02-12-2013, 03:43 PM   #6
TROOPER 247
Yes sir, the factory speaker bracket fit turnswitches aftermarket one just like like the original. I didn't modify anything.
Old 02-12-2013, 04:13 PM   #7
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Here is a link to the speaker. Its about half way down the page.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-12-2013, 11:05 PM   #8
atvpro
atvpro's Avatar
thanks for that info. I need a new speaker myself.
atvpro is offline   Reply With Quote
Old 02-12-2013, 04:30 PM   #9
Mister-B
Thanks guys!
Old 02-12-2013, 06:19 PM   #10
rsavage
rsavage's Avatar
They must have changed their name in the last few years - they went under "Electro-Tech" when I dealt with them. In any event, they do it right.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-12-2013, 10:05 PM   #11
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
A side note if you want to / have to use modern 4 ohm speakers: Wire two 4 ohm speakers in series to see an 8 ohm load at the radio. It isn't the 10 ohm that the stock speaker is, but much better than a 4 ohm load for it.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-13-2013, 01:08 AM   #12
allchevy58
allchevy58's Avatar
I just bought the 4 X 10 replacement from Electro-Tech in November. It fit perfect and sounds great. $59.45 shipped to my door.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
