![]() Join Date: Dec 2004
need a pic of exhaust manifold
i am needing to change my exhaust manifolds from the factory truck ones to something smaller, like maybe the trailblazer ones,,does anyone have a pic of the trailblazer ones with measurements so i can see if they will fit,my motor might be sitting just a hair low in the frameand i need to see if i need to raise it up, or if those will work,,mainly need how tall, how widefrom the flange.thanx
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
Re: need a pic of exhaust manifold
here is a whole thread just for trailblazer manifolds
http://67-72chevytrucks.com/vboard/s...d.php?t=530623 if this doesnt get you what you want let me know and i can measure any specifics for ya.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
meowMEOWmeowMEOW
I don't have measurements, but here are some shots I have of the TBSS manifolds, off and on my 66/lq4.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jun 2012
They will fit. I have been following your build and I know that you are using the AA adapter. I am doing the same thing and I kept my TC in the stock position and my engine is at 5 degrees. The flange on the passenger side is close to the frame rail but they fit with no trimming. I will try to post some pictures tomorrow.
i agree, and after looking at the pics im sure they will,,and to buy them for 125 shipped is a killer deal right now since just the right side is going for that on ebay
Collector of Projects
I have a set of 2010 Camaro manifolds on my K5...
2010 Camaro manifold... Camaro on the left, Sierra on the right... ![]() Its 7" from the last manifold bolt on the head straight down to the flat gasket surface of the flange. It sticks out 5.25" from the side of the block at its widest point. (Opposte of where the starter would attach.) ![]() ![]() ![]() Last edited by mcmlxix; 02-14-2013 at 02:53 AM. |
Here are the pictures. I got my TB SS manifolds and heat shields from GM parts Direct for about $180.00 to my door.
nice....you should really have a build thread, i would like to see more of your project
![]() Join Date: May 2005
JJH JImmy.... great looking exhaust.... Where did you get the flanges for the Tbss manifolds???
When i got my engine it came with the truck manifolds with the flanges and the chunk of pipe with the o2 bungs. I cut them off and welded them to the stainless tubing using 309 wire.
Great.... how close is the right side, lloks close but may be the camera angle
![]() Join Date: Apr 2005
I've got a set of exhaust manifolds off a 2013 Camaro SS with only 135 miles. If they will work for you, shoot me a PM.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
