Old 02-14-2013, 06:08 AM   #1
melhilburn
melhilburn's Avatar
Driver side window sticking
on my 64 the driver side window is almost impossible to roll down without a little help pushing down on the glass while turning the crank - It will roll up without any problem at all????
melhilburn is offline   Reply With Quote
Old 02-15-2013, 11:34 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Driver side window sticking
Sounds like you may have a little slop in the window regulator linkage and it is causing the glass to bind in the track when rolling down. When you roll it u the linkage will shift a little and cause less binding. You can try removing the door panel and clean/lube all of the regulator linkage and see if that helps or just replace the regulator.
TBONE1964 is offline   Reply With Quote
