02-14-2013, 11:54 AM | #1 |
driveshaft angle with pix
will this be ok? the tailshaft out of the transis about 6*. not sure if this is the right way to degree this. trans is a 4l60e w/ls1 out of a 2001 camaro.
02-14-2013, 12:03 PM | #2 |
Re: driveshaft angle with pix
Typically the difference between the tailshaft and pinion should be 2-3 degrees.
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
02-14-2013, 12:25 PM | #3 |
How should I figure out the difference? Do I unbolt the driveshaft from the pinion and put the angle finder on the flat part. Thanks for your help
Posted via Mobile Device |
02-14-2013, 02:06 PM | #4 |
2WD Jimmy
Output shaft on tansmission should be the same as the input on the rear end. Also, that driveshaft ought to be into that tranny about 2 1/2" further.
02-14-2013, 02:35 PM | #5 |
That is how far it was in on the camaro. Its it at the same ware line on the shaft.
02-15-2013, 06:29 PM | #6 |
I agree, your driveshaft looks a little short. How long is that tailshaft? If it's too short, you'll tear up the bushing in the tailshaft and then have other things to worry about.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-14-2013, 03:27 PM | #7 |
two piece drive shaft ?
02-14-2013, 03:48 PM | #8 |
Sorry it is a 1pc driveshaft
02-14-2013, 04:00 PM | #9 |
Man of Mini-Talents
Are you at ride height or fully dropped?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-14-2013, 04:38 PM | #10 |
That picture is with the truck at stock height. I plan on doing bags with ame c-notch. when I do the angle of the drive shaft will get worse I assume.
02-14-2013, 04:42 PM | #11 |
Man of Mini-Talents
Right. Do you have room between the trans and the cab floor to shim the transmission mount?
02-15-2013, 12:51 PM | #12 |
Just noticed this .. Sorry Big Steve!
02-15-2013, 01:11 PM | #13 |
I might have at max a 1/4" to play with. It is pretty tight between the tunnel and trans.
02-14-2013, 05:07 PM | #14 |
the boat guy
Should be 2.5" from tailshaft to center of front ujoint.
Your pinion angle looks fine, for now.. wait you never posted your pinion angle. The trans output and pinion should be parallel. The driveshaft shouldn't be any more than 3* different than your pinion/trans output angle. Posted via Mobile Device |
02-14-2013, 05:45 PM | #15 |
Ok when I get home I will degree the pinion, driveshaft and tail shaft. Is there any special way to degree the pinion?
02-14-2013, 10:59 PM | #16 |
Ok the tailshaft is at 6* down and the pinion is at 4* up. Will this be ok?
02-15-2013, 12:18 PM | #17 |
Anybody?
02-15-2013, 03:48 PM | #18 | |
A day late and $1 short...
What transmission crossmember are you using?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-15-2013, 05:12 PM | #19 | |
02-15-2013, 12:45 PM | #20 |
I think I might shim the trans mount up about 1/4" and re-measure.
Just something to consider, when you accelerate the pinion will rotate down. .. so your 4* up is okayy .. but it will quickly go to 1-2* or so as you pull away from the stop lights. If I am thinking correctly, if you shim the trans mount up just a hair wouldn't that put them close to equal but not zero'ed out ? Just to add something else for you.. read through this kit writeup. It will make it all make more sense (it did for me) I know this is S10 stuff, but I promise I used this kit on my 96 S10 ext cab it has ZERO vibration in it anywhere. It is smoother now than it was from the factory. I'm sure the same concept applies to our C10s. http://www.jagsthatrun.com/Pages/Par...aft-Align.html
02-15-2013, 06:41 PM | #21 | |
the boat guy
I rebuild at least 3 a week. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-15-2013, 01:38 PM | #22 |
CC69.
THe pinion rotates up. THat's why some people install a pinion snubber on the nose of the rearend to limit the upwards travel. |
02-15-2013, 01:47 PM | #23 |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-15-2013, 03:10 PM | #24 |
Its a Truck Thing......
Coils or leaf's?
If your running coils, here is some info for shims. I am running them and they work great. http://67-72chevytrucks.com/vboard/s...d.php?t=369008 Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
02-15-2013, 03:15 PM | #25 |
You know what.. youre right. My bad. If youre hanging upside down under the bed doing stunt work.. it rotates down.
Sorry.. thanks for helping me out. Im braindead today. Posted via Mobile Device
